Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Supporting Vendor Group Purchases
Old 05-01-2005, 05:01 PM
Moose Moose is offline
Originally Posted by [email protected]
what kind of vehical is this going on?
You can't read my mind LOL.. (sorry)
69 camaro...
Old 05-02-2005, 03:10 PM
david@ronsraceshop's Avatar
david@ronsraceshop david@ronsraceshop is offline
69 camaro...
Moose,
Category 5 costs $3995.00 from Global West, this Group Purchase this cost is $3795.00. This includes 11.75 inch or 12.inch disc brake applications. for the 13.00 inch disc brakes add $200.00 dollars to the $3795.00
This is a Complete Negative Roll CAT-5 System for the Front
Cat 5 System for the Rear is $824.00 from Global West. This Group Purchase this cost is $782.80.
Global West nor Rons Race Shop Recomend using the Coil Over with this system do the Small Spring Rates on the Coil Over Shock System. If your you want the Coil Over shock then just get the tubluar Upper and Lowers and make sure you have a 1 1/4" thick front sway bar.
This Kit will make all First Gen Camaros and 68-74 Novas Handle like SCCA or 24hr Lemans Cars.
David@RonsRaceShop
VP RonsRaceShop
1971 RS Camaro
SBC 396 cid .... Comming Soon
ATS Spindles ..... Comming soon
14" Corvette Brakes with 6 piston Calipers ... Comming Soon
Tremec TKO-600
ROH 18x8 Front Toyo Proxes T1s
ROH 18x10 Front Toyo Proxes T1s
100-0 .... 185ft
60-0 ...... 110ft
13.40 1/4 mile
109 MPH 1/4 mile
Old 05-02-2005, 03:40 PM
I'm waiting on a price for the wilwood brakes and will be back to you shortly.
Who does the brakes for the cat 5 system? and are the drilled rotors??
email is [email protected]
Old 05-03-2005, 12:23 PM
The Brake System is made by Global West this unit is designed and built by global west using stock car technolgy and the willwood 4 piston caliper.
David@RonsRaceShop
VP RonsRaceShop
1971 RS Camaro
Tremec TKO-600
100-0 .... 185ft
60-0 ...... 110ft
13.40 1/4 mile
109 MPH 1/4 mile
