Old 05-14-2007, 06:32 PM
Steve1968LS2's Avatar
Originally Posted by ironworks
Your 100% right that the F-body alone will not make a pulley system to long except in a Vette or GTO. But an aftermarket system that bolts another pulley to the front of an Fbody dampener, is gonna be really long. Like almost 7 inches. The billet specialties kit is the shortest on the market except factory. Most everybody has to have that bolt on pulley which is what I'm saying about being too long.
Hmmm.. my fbody pulley system just uses the dapner as the pulley. The AC is the biggest issue using an f-body system but that's not a problem for me. lol
Let's not confuse WIDTH with LENGTH .. The AC issue is one of width.. the extended pulley is one of length..
Every AFTERMARKET needs a pulley bolted to the dampner. The factory stuff doesn't generally need it.
I think systems like the DSE, Sinister, ATS and such are much better looking. I just like my accesories as low and tight as possible.
Old 05-14-2007, 06:47 PM
rich-allen's Avatar
rich-allen rich-allen is offline
Originally Posted by camcojb
EVERY GM system I saw that included a/c stuck out much further than the Synister system. The GTO setup isn't bad, but I didn't want to mod the frame and must have a/c. Not sure what you mean here, unless by sticking out further you mean more towards the radiator. I was looking for something tight, inside the valve covers. This doesn't look stuck out to me:
Damn that system looks sweet! I called synister this afternoon, the guy told me that the system required you run and F-body water pump and aftermarket dampner.
I forgot to ask if the system was complete including WP and Dampner. I do remeber the price though. $2300.
Did the PS pump & reservoir come from Synister?
Old 05-14-2007, 06:56 PM
rich-allen's Avatar
Originally Posted by Steve1968LS2
That must be including the PS pump, Alt, AC compressor and everything.. I certainly don't have near that in mine.
An alt bracket (for an f-bod) is around $30.. cheaper used.
Acually GMPP has a complete kit Part# 19155067 including all the brackets, bolts, AC, PS W/Reservoir, Alt, idler, and all pulleys for $775.00
It's in the new performance catalog and will be availible 6/1/07.
I was going to order it but if I run AC I have to notch my frame and I'm not crazy about that.
Old 05-14-2007, 07:03 PM
ironworks's Avatar
We build all kind of cars Muscle cars, street rods, pick ups, and racecars We have had lots of problems in quite a few cars.
Old 05-14-2007, 07:18 PM
camcojb camcojb is offline
comes with everything; ATI balancer, water pump, ps pump, etc.
Old 05-14-2007, 07:41 PM
With what?
pushrod243's Avatar
pushrod243 pushrod243 is offline
what about ATS? It looks pretty nice too...
John
Old 05-14-2007, 08:35 PM
ATS is great, just not available yet.
Old 05-14-2007, 08:46 PM
va72mlibu's Avatar
va72mlibu va72mlibu is offline
Billet Specialties says that their's works with LS2 but requires "Drivers Side ETC" (electronic throttle body). I'm not aware of GM making one of these, so do you just run the ETC "upside down"?
Eric
'72 Malibu - The FULL RIDE, LS7 power, Optima juice
'05 Volvo S60R, (my Swedish Hot-Rod)
C-12 Huron (operated but not owned)
Fquick page
Old 05-14-2007, 09:10 PM
I know that's what Magnacharger does on the 05/6 LS2's, flips the throttle body over.
