Old 05-16-2007, 04:15 PM
JamesJ JamesJ is offline
On page 64-M of that packet there is a picture of a "sealed remote AIC housing" do you have any info on that? I will be using a procharger with 12 pounds of boost do you think that I need to get that. I will call them and ask them for there opions as well.
James J.
Old 05-16-2007, 04:28 PM
camcojb camcojb is offline
Originally Posted by JamesJ
You are correct, but I am mounting mine upside down so then it would be on the top and I dont think that I am going to have the hood room. That is why i am using the remote style one. I have just put a plate over the area that the AIC would mount to.
I think I am going to order that one from Kinsler.
If you get me a pic of your throttle body where the IAC mounts, I probably have a billet aluminum blockoff for it you can have.
Old 05-17-2007, 01:46 PM
Thanks, I have already made a aluminum plate for it.
Any ideas on the sealed remote housing?
James J.
Old 05-17-2007, 02:05 PM
Not sure what you're asking. You can get the remote IAC housing and filter from Kinsler in the link I posted earlier. Not sure whom else sells it.
Old 05-17-2007, 02:10 PM
On page 64 they (Kinsler) has a sealed housing they sell that they say you need to use for boosed aplication
James J.
Old 05-17-2007, 02:42 PM
good point, you'll likely need it. Otherwise you would have a leak under boost.
Old 05-17-2007, 10:05 PM
surreyboy
Guest
Posts: n/a
Bds also sells it if anyone already deals with them
