Old 06-14-2007, 11:20 AM
nitrorocket's Avatar
Default Thought on tires/handling on my Chevelle.
On the way to work this morning I ran into a newer Subaru WRX STI with some exhaust and possibly some other hidden mods. He was trying to mess around so I thought I would play too.
He tried to pull me from a light and I stayed on his rear and then we entered a 270 degree right hand turn for a freeway onramp. I was in 3rd which was to low high a gear for the turn so half way through I had to downshift to 2nd.
Anyways, besides me being very nervous about the ass end sliding out, I could not pull on him in the turn and actually lost a car length,I had my radio blasting so I could not hear my car. I may have been able to push it harder as I assuming he was, but my last experience with this turn I had my rear almost slide out from cold rear tires in the early morning. I was dissapointed I could not easily hold his bumper or pull on him and I actually lost about 1 car length to the WRX.
My car felt like the ass end wanted to come around, I was trying to fight that a little, I am hoping it was just a tire issue and not suspension tuning. I wish I had my radio down so I could have heard the tires.
What do you think of this, and what is the the opinion on rear tires, I run a Goodyear Eagle GSCS road race slick on the rear (315/35/17) I nees to do something, just not sure what.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 06-14-2007, 01:10 PM
Blown353 Blown353 is offline
I can chime in on this as I own both a Chevelle and an STI.
The STI is a fantastic car when it comes to handling. Yes it has a tendency to understeer from the factory especially if you don't know how to drive it and set up your corner entry correctly but if you can get it into the corner correctly it has HUGE amounts of cornering grip and is very stable. If you do a little suspension work to them to dial out some of the understeer then they're even more fun.
With the Chevelle's longer wheelbase and quite a bit of extra weight you're already down 2 points... and the STI is a far more stable & composed chassis in hard cornering especially if there are any road irregularities involved. In corners over imperfect roads where my Chevelle will skitter sideways a little bit (especially the rear end) my STI just sticks, sticks, and sticks.
Given a "driver mismatch" (poor driver in the STI and an excellent driver in the Chevelle) you might have a chance... but the problem is the STI's chassis is so predictable and well balanced you have to be REALLY ham fisted to screw things up, to the point I'd say with an average driver in the STI compared a good driver in the Chevelle I'd probably even put money on the average STI driver. Also, the factory RE070's on the STI are darn near R-compounds from the factory. Sure they're louder than a set of Super Swampers but they are AWESOME tires in the grip department.
Also, running road race slicks on your car is probably limiting your grip on the street as I doubt you can build enough heat in them during "normal" driving to get them to really start sticking. A good example would be to try driving a car on Hoosier A-series then R-series. The A-series autocross tires start off sticky when cold but lose grip and get greasy as they get too hot, whereas the R-series roadrace versions start slicker but get sticker as heat builds in them. Different purposes for each tire-- the autocross tires start with no warmup and only have to make a 45 second or so run, whereas the roadrace tires get a couple warmup laps but then have to survive a 20 or 30 minute session. I'd venture a guess that a street/autocross oriented R-compound will yield better traction on the street than a full road race slick as you don't need to build as much heat to get the grip.
Summary:
Just wait for the turn to straighten out then pass him.
1969 Chevelle
Old 06-14-2007, 02:54 PM
Steve Chryssos's Avatar
I' don't think any street tire will support four digit power. I'd be looking into traction control.
http://moretraction.com/
________________
Steve Chryssos
Ridetech.com
Old 06-14-2007, 04:12 PM
I know and I dont expect to.
I am hoping to find a tire for the street that will last longer then 2 months that will corner amazing ans dtill provide some straight line grip.
6 speed
Old 06-14-2007, 06:31 PM
LateNight72 LateNight72 is offline
You may look into the Nitto NT01.
It's a Traction "A", Temperature "A"
Avaliable in a 315/35/17 like you currently have.
-Todd
Old 06-14-2007, 06:42 PM
I will check into it!
6 speed
