Old 04-20-2012, 03:07 PM
cencalc6 cencalc6 is offline
That's going to be a Sik setup under the hood!
Are you going with Twins or Single?
Old 04-20-2012, 03:19 PM
John510's Avatar
John510 John510 is offline
2 Turbonetics T04E T3/T4 57mm Turbos
2 Turbosmart ultragate 38mm wastegates
1 Turbosmart raceport BOV
8 LS3 60lb Injectors
Stainless piping with Aluminum charge pipes
Innercooler
[SIGPIC][/SIGPIC]
Old 04-20-2012, 03:29 PM
Innercooler
Old 04-20-2012, 04:50 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Looking Great John, You didn't happen to see mine while you were there did you?
Greg
Old 04-20-2012, 04:54 PM
John510's Avatar
Greg
No sorry I met him at Apple not at the shop.
[SIGPIC][/SIGPIC]
Old 04-20-2012, 05:24 PM
Ron in SoCal's Avatar
Innercooler
Hey John - Absolutely love the underhood design and execution! A couple questions for you - do you know what the inner cooled intake temps will be on a TT set up and are those within spec for a carbon intake? Also, what boost PSI are you planning on running? I believe that's still a crate motor/stock compression right? Finally will exhaust route clear steering shaft - have you got that far in your planning?
You're on a roll Bro. I can't wait to see this one in person...
Ron in SoCal
69 Camaro in progress
Old 04-20-2012, 05:40 PM
John510's Avatar
The intake is made with high temp resin and can handle the heat at at least 30 psi. It was pressure tested at 100psi. I am unsure on the intake temperature. Waste has a 7psi spring. Don't plan on going over the 7psi since the block is stock. I figure with the cam and 7psi I should still be around 600rwhp which is enough for me. I don't really need an insane amount of hp for a street car. The down pipe should clear the steering shaft no problem.
Now I hope my Anvil fenders don't melt!
[SIGPIC][/SIGPIC]
Old 04-20-2012, 06:18 PM
Excellent John! You'll be burning tires and smiling @ 600wheel + the motor will live
Ron in SoCal
Old 04-20-2012, 07:55 PM
scherp69's Avatar
scherp69 scherp69 is offline
Looks awesome John. That intake is sweet. What column ring is that? I'm still trying to find a nicer one for mine.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 04-20-2012, 08:47 PM
John510's Avatar
It is a swivel ball floor mount from Ididit. Thanks for the compliments
http://www.ididitinc.com/accessory_p...oor_mounts.htm
[SIGPIC][/SIGPIC]
