Originally Posted by ohcbird
Steve- are they going to put vibration isolators on the Setrab?
That's a good looking piece.
They are there.. put them in myself today. Small pads at each of the four attachment points. Came with the Setrab mounting brackets.
Power guesses? Hmmmmmm...need more specs (too lazy to surf the old posts at this point). My spider-senses tell me the driver is going to need to be retuned as well haha.
247/261 114 cam
461 cubic inches
11.5:1 compression
Lunati 4.250 stroke crank
I-beam 6.125 rods (609 grams)
Wiseco pistons
Mast Motorsports 12-degree big bore rec port heads
FAST 102mm LS3 intake
RHS race block, standard deck, raised cam - 6-bolt
Mike Norris ported LS2 TBW throttle body
And a bunch of other stuff that don't make power.
It will most likely make more than I need.. so I'm not going to be able to just flat foot it like I did before. I'm thinking I'm also going to have to run short autocrosses like Goodguys in second gear.
