Closed Thread
Old 02-22-2011, 06:29 AM
g356gear's Avatar
g356gear g356gear is offline
Since then I found that my throttle cable had stretched and I was getting 15/16th throttle.
Gee.....how could that possibly happen....
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
  #1992
Old 02-22-2011, 09:42 AM
Sieg's Avatar
Sieg Sieg is offline
Not that he ever pushes the envelope with the car. When adjusting the throttle cable he might want to factor adrenaline induced floorboard flex.
  #1993
Old 02-22-2011, 11:42 AM
Flash68's Avatar
Flash68 Flash68 is offline
Car looks tits Todd. Ready to go. Yours are the Modo pedals, correct?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
  #1994
Old 02-22-2011, 02:32 PM
awr68's Avatar
awr68 awr68 is offline
Sparco I believe.......
Tony
'68 Camaro
  #1995
Old 02-22-2011, 03:00 PM
Sieg's Avatar
Looks like their Grip series: http://www.sparcousa.com/ptuning_pedals.asp?id=351
Todd - Are you satisfied with their performance?
  #1996
Old 02-22-2011, 05:11 PM
I don't recall my foot ever slipping off a pedal in all my miles and racing. I did have two of the rubber pads pop out but they have stayed put every since.
I like to set the throttle so the pedal arm bottoms out on the floor board INSTEAD of putting all the strain of my right foot and adrenaline on the throttle cable and throttle shaft. It's tricky getting it right but I feel it should be more reliable.
  #1997
Old 02-22-2011, 06:30 PM
hifi875's Avatar
hifi875 hifi875 is offline
tha dash is killer, makes me want to get rid of my covans/ultalite setup really bad.
  #1998
Old 02-22-2011, 07:16 PM
Sieg's Avatar
Wouldn't fabricating an adjustable throttle stop on the floor/firewall pan be possible? Then you'd have throttle shaft and pedal travel adjustments.
I think we'd be surprise with actual telemetry data for psi load on the throttle pedal stop recorded during the heat of battle.
  #1999
Old 02-22-2011, 09:10 PM
I've thought about that but don't need it. The pedal arm bottoms out on the firewall itself. I wouldn't mind a higher pedal for racing but not for street cruising. My pedal arm is splined for large adjustments and the small adjustments can be made at the throttle bracket housing and connection at the carb.
  #2000
Old 02-23-2011, 04:44 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Just an awesome car overall. That car can go grab some beers on a weekend run and rip up the auto-x on another weekend. Very nice Todd.
Closed Thread
