Old 09-12-2013, 08:34 AM
OBeer-WAN-Kenobi's Avatar
Man, I stayed away from this thread (because I know how it goes) for quite a while hoping that when I came back Dead Pool would be laying some rubber down. Much to my disappointment, "laying some rubber down" seems to mean the wheels laying on their sides underneath the car.
Seriously though, that exhaust is looking and probably sounding good as well. I can't get a good idea with the video and playing it on my crappy laptop speakers.
Come on Ron!
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 09-12-2013, 04:16 PM
U-turn U-turn is offline
Come on Ron!
I'm with him!
Old 09-12-2013, 07:47 PM
Ron in SoCal's Avatar
Come on Ron!
Originally Posted by U-turn View Post
I'm with him!
^ I'm with you guys! Sorry, stuff only moves as fast as brain power and vendors go, not to mention
It's gonna be a couple weeks before I get parts back and installed and something new happens. I gotta live with that, but am very motivated to get on it so I can get some wheel time in before next year.
Thanks for the tho, lol
Ron in SoCal
69 Camaro in progress
Old 09-12-2013, 09:26 PM
It's 1st and goal buddy...
Old 09-28-2013, 03:24 PM
Shocking Update
So I’ve had Ron Sutton on speed dial for a while. The man is an absolute wealth of knowledge and his explanations are such that concepts become working knowledge. Me saying that is scary, I know. Before I go any further, props to Herb, Darren and Britt at Ridetech. Not the first time I’ve dealt or spoken with these guys and the service and attitude is top notch. Brett if you’re reading this, I believe that starts at the top and you run a first class outfit.
Some of you may remember the One Lap Three Amigos doing some pre-race test and tunes here in SoCal. Ridetech and Fox were out that day and they did some rebound adjustments and it worked out pretty well for those guys. Ron Sutton and I had already done some calcs on springs and swaybar rates, so I checked in with Herb Lump at the shock desk (great guy). He sent me the before and after dyno graphs and stated that the addition of a rebound adjustment helps track times but that the shock “liked more spring rate” when they added rebound. Here’s where the journey begins.
I sent Ron’s shock builder my shocks for dyno and revalving. From the dyno graphs Ron concluded the low speed rebound valving was too soft. Not wanting move away from Ron’s proprietary valving curve for optimum track performance, the shocks needed stiffer rebound valving at low speeds without pushing the high speed valving too high. Low speed valving in the 1” to 3” per second range is key to handling performance, but higher piston speeds control bumps.
A part of Ron’s secret sauce is achieving much stiffer low speed rebound valving, to keep the front of the car down during a corner, while not being too stiff in the part of the curve that affects bumps. This requires a digressive rebound curve. They did a lot of testing, but everything tried (shim stacks, replacement pistons) could not get the rebound as digressive as Ron wanted it. Ron took the time to work with Herb and Britt at Ridetech and they discovered Fox had a design for a digressive plate which would allow the rebound to be less linear at the top (higher piston and shaft speeds).
After reviewing the design, Ridetech made the digressive plate in-house. Darren shipped it out overnight to Ron’s shock guy. Ron says the digressive plate is just one piece of the puzzle, but with fine tuning of shock valving and piston bleed circuits, they tailored the curves to achieve Ron’s proprietary curve. After some testing and adjustments, along with Ron’s input on where and how he wanted the shock to perform, the shock was blessed and shipped to me this week. Yeah, it took a while; five parties had to be happy, but in the end it worked out great. I put the shocks back together last night and I’ll take them down to BoS and install them very soon.
At this point, we know the dyno graph looks great but really the proof will be how they perform. We won’t know that until the car hits the track. On paper you can make any shock look right with valving, but some brands will push you right into the wall when valved beyond their limits of grip control. I’m certain the Ridetech units will not have a problem as we didn’t set them on NASCAR (BMF) full kill.
More on this to follow!
I think I just burned up two more downs
Ron in SoCal
Old 09-28-2013, 03:33 PM
When this car is finally finished and you've calculated every 10/1000th of a thing a ma jig ----- I sure hope you can actually drive...
Old 09-28-2013, 03:43 PM
Exactly my thought...There certainly won't be any excuses.
Old 09-28-2013, 04:07 PM
fleet's Avatar
fleet fleet is online now
Ronnie, you saved the best for last...or now.
So there's 4 of ya...or 2
depending on what category the 'Ronnies' fall in.
Old 09-28-2013, 04:18 PM
Don't count on it. I'm 'compensating'
It's racing. Everbody has an excuse.
Ron in SoCal
Old 09-28-2013, 04:21 PM
Ha Skipper, I just take four years to build a car that should be done in two. That allows me to do that 10/1000th's thing Iron man was referring to above.
Ron in SoCal
