Old 04-22-2015, 03:09 AM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
Scott, it sounds like the geometry is altered in a bad way to achieve the desired ride height. Wow, I've never heard of that happening before. LOL
If it were me, I'd put big block springs in the car to get the correct geometry, and suspension travel. Then run drop spindles to achieve the ride height your looking for. That is what I had to do on my AMX chassis. Even with an aftermarket frame stub. Geometry and travel, trump everything else.
Old 04-22-2015, 05:16 AM
SSLance's Avatar
SSLance SSLance is offline
I was going to go kind of the same route, on my car I spent countless hours cycling the front suspension with the springs removed trying to gain as much travel as I could. The more it traveled, the more stuff hit. Once I had everything clearanced and all of the travel I could get, I then measured for shock length and calculated which springs to use.
I started with about a half inch between my bump stops and the frame as well, I now have almost 2" of bump travel up front and the car only sits about a half inch higher at ride height than before.
Lance
Old 04-22-2015, 06:55 AM
Just ditch the wubba stops.... problem solved.
The thing to have done was to run the suspension/travel with wheel/tire mounted -- sans spring - and see what clearance issues you'd have - and then weld a stop where it needed to be for "protection" purposes.... or find/modify a wubba stop to work.
So now you can disassemble the suspension on one side and do that.... HAHAHAHAHAHAHAHAHAHA
Old 04-22-2015, 07:46 AM
Sieg's Avatar
Sieg Sieg is offline
You mean mine isn't the first one?
Agreed on longer springs and drop spindles as the proper cure. With the current pro-tinkering budget altered wubba stops and spacers will probably prevail.......technically it 'should' will be an 'improvement' from where it was.
2" eh............Bragger!
I did cycle it w/o springs, but with the stops. I optimistically put it back together to know where everything sits at ride height knowing it would most likely be disassembled.........again.
I'll have disassembly and assembly of these archaic front ends down pat when it's all said and done........whoopie.
I will say that using the flexible cutting boards for turn plates was really slick, pun intended. Though I did need one last night for dicing asparagus.
Old 04-22-2015, 08:11 AM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Norwood
Reminds me of the 800lb springs I had put on
the Firebird years ago... when I got it back from
the suspension guy ( a Norcal Shelby Otec guy) I
told him it sat too high.. he said the geometry was
perfect and go run it to see how it does... next event
I won and the car was on rails..
I went back and said it ran great but looks like crap
he said Dropped spindles would fix it... no one made
them at that time so I left it... now we have new arms, spindles,coilovers,
taller ball joints, different size bump stops,etc, etc.. where does it stop
Bob
Old 04-22-2015, 08:13 AM
57hemicuda's Avatar
Just so you know we're all white men Lance. Mine has 3" of compression, and 2" of rebound.
Old 04-22-2015, 08:02 PM
glassman's Avatar
glassman glassman is offline
On my last set-up, i left the bump stops but cut them down to 3/4 to 1" at LCA (i had cut the snot outa my hotchkis springs to get desired ride height) once cut, no bump (well, when i wasn't dukes of hazzard'in it), i tend to drive the car like my Katoom, perhaps i should stop doing that.....
Mike
Old 04-22-2015, 08:56 PM
Judging by your control arms and bump stops, you have way more rebound than compresson available in your suspension. Is your shock in the same place in the stroke? Let's pretend you have 1.5 inches of compression left at the wheel. That will likely result in half that at the grease zerk?
Taking some measurements and then running the suspension through its range without the springs will allow you to dial it all in. Raising the car will need to happen either way if you want to be anywhere close to your shock sweet spot and greatest handling capabilities.
This is why people buy subframes.
Old 04-22-2015, 09:50 PM
Vince@Meanstreets's Avatar
As long as you don't drop it too fast off the floor jack....I don't see any issues.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 04-23-2015, 07:10 AM
Sieg's Avatar
Judging by your control arms and bump stops, you have way more rebound than compression available in your suspension. Is your shock in the same place in the stroke? Let's pretend you have 1.5 inches of compression left at the wheel. That will likely result in half that at the grease zerk?
Now that I've removed MY speculation by putting it on it's own weight and seen the clearance issues first hand, the spring spacers and shorter bump stops are in transit. That's certainly not going to make it ideal but it may be an improvement from the original setup and where it sits currently. Far from ideal, but with the firmer springs and spacers it could deliver twice the compression travel of the original setup and be in the softer valving range of the shock depending on how the Koni's stacks are setup. Won't know until it's on the ground and driven a bit......hopefully the springs don't dramatically settle into the pockets even though I've tried to put them in their 'sweet' spot.
.......and adjustable coil overs
.......or C5 Z06's
.......or Miata's in my situation.
