Old 04-29-2012, 06:55 AM
Wow, happy day for sure! Going to be nice when done
Old 04-29-2012, 07:42 AM
Sonar Chief's Avatar
Smile
Thanks ... happy day for sure. She's coming along nice, now I can sandblast the areas that need to be POR'd in the driveway and not make a mess in the garage BIG PLUS
Thanks for looking!
Old 04-29-2012, 04:26 PM
Smile 4/29 Started the cowl....
Fitting the cowl today and nothing was lining up, go figure Taiwan POS, so I measured off the old piece and they are not the same. So I decided to take off the old corner pieces (lines up the fender bolts) and use them instead of the POS already on there.
Just need to POR15 them and then I can weld them in place and start lining up the side cowls.... man it's goood to measure off the frame knowing it's square
I didn't trust those nuts anyway!
Got the cowl level and it lines up now!
Geee ... the bolt holes line up with the firewall now, kool.
Nothing too big ... but that was bugging me so I had to do the right thing
Thanks for looking,
Michael
Old 04-30-2012, 05:59 AM
makoshark makoshark is offline
You're making some great progress! You'll be setting up suspension here soon. Have you ordered any of it yet?
Old 04-30-2012, 03:15 PM
Thumbs up
Thanks .... been waiting on your pixs and fell asleep
No I haven't ordered any suspension parts yet, figured I'd get the body ready and save $$$$ and go from there.
I did ran into a snafu with the POS side cowls last nite, I'll post some pixs tonight and get some ideas!
Old 04-30-2012, 06:53 PM
Angry POS side cowls!
The fit of these side cowls are horrible, if I clamp them to the hinge support like the original there is a 3/8 gap to the firewall, the dang things are not wide enough.
And the outer panel is the same width as the side cowl ...grrrrrrrrrrrr so I can't just slice and weld in the diff .... any ideas? Other than return and hope someone else has better quality, would like to find an OEM but that may prove to be difficult.
Has anyone replaced side cowls with better luck than I am having, please chime in.
Gap with the cowl clamped to the hinge support.
Ditto ... those circles are where the OEM was welded.
Clamped to the firewall and short on the inside
Old 04-30-2012, 06:59 PM
Dang, those do fit like sheeot. I don't know what to do other than drill out the spot welds on them and make them fit better that way
Old 05-01-2012, 07:18 PM
Naw ... I'm returning these POS and will get some AMD parts when they are in stock. Craig Hopkins at the AMD installation center said all their parts are test fitted and should fit like OEM
I should have order from AMD in the first place ... lesson learned!!!!
I did get the floor pan cleaned and POR'd the rusted spots ... it's something while I'm waiting on parts.
Thanks for looking
Old 05-02-2012, 08:10 PM
Thumbs up 5/4 Update
Got to work on the cowl assembly tonite, filled the holes from removing the old corner pieces and drilled new holes similar to OEM, and then welded the POR'd corner pieces at the correct width (52 3/4") across the cowl.
Everything lines up well A little more work on the welds and then get some black POR15 .... but that's another day!
Welded the corners.
POR15 black needs touching up!
Work in progress while I'm waiting for the side cowls
Thanks for looking
Old 05-05-2012, 07:58 PM
Thumbs up 5/5 Update
Bolted the front fenders to the cowl to make sure everything lined up (still waiting on my side cowls before I weld anything to that cowl!) Then I decided that I would take the fenders down to metal while they were bolted to the body, I still need to DA them, so yesterday and today I that's what I did
I still need to get in the jambs with the fiber disc.... but overall she came out nice. This way when I am ready for epoxy primer I can do the whole car at once .... that's the plan anyhow.
Bolted the NOS fenders to the cowl!
Couple hours later ....
Another day of sanding.
