05-01-2023, 02:00 PM
Kicker Under Carpet Wiring (( 04-13-23 ))
Hi All,
There has not been a lot of progress lately due to lack of time. The charity ( www.ridejanieride.org ) that I part of main
event is coming up this weekend and I can't wait. I have been trying to sneak out whenever possible.
It's finally time to tuck the wires under the carpet in the TechFlex undercarpet flat weave.
I used some Velcro to keep the heat gun trigger on and my bike stand to hold the heat gun.
I marked out where the Bitchen center console the Kenny built.
Wire has been neatly routed and protected.
I also received the DEI Under Carpet Lite heat insulation that I will be using in the rear of the car.
I plan to add a little extra in the rear adjacent to the DSE Sub-Frame Connector.
and don't forget to Buckle Up out there.
The Following 8 Users Say Thank You to syborg tt For This Useful Post:
06-01-2023, 12:18 PM
I made another To List (( 04-17-23 ))
The Following 2 Users Say Thank You to syborg tt For This Useful Post:
06-01-2023, 12:33 PM
More Small Projects (( 04-24-23 ))
06-01-2023, 12:48 PM
Installing more X Mat (( 05-02-23 ))
06-01-2023, 01:06 PM
Terminator X - Fuel Level Wiring (( 05-06-23 ))
I needed connect the fuel level wire to the Holley ECU and of course I forget to run the wire down the passenger
side of the car. I did however run it down the drivers side but Holley wire I needed was on the passenger
side. So, now i have to neatly behind the Vintage Air Unit. Which turned out to be a major pain the backside.
I of course wrapped the shifter brackets with a towel as they are sharp as can be.
See those gray wires they are being relocated to the drivers side of the car.
Temporarily connected
06-01-2023, 01:12 PM
Custom Works Front Tow Hook (( 05-08-23 ))
I finally pulled the trigger and ordered one of these
06-01-2023, 01:23 PM
Another Small Project (( 05-14-23 ))
The Following User Says Thank You to syborg tt For This Useful Post:
06-01-2023, 01:28 PM
Gates Power Grip Hose Clamps (( 05-14-23 ))
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
06-02-2023, 06:58 PM
Coming along nicely, Marty!
06-03-2023, 02:08 PM
Great updates Marty, as usual.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
The Following User Says Thank You to 214Chevy For This Useful Post:
