Closed Thread
Old 06-18-2011, 07:20 PM
g356gear's Avatar
g356gear g356gear is offline
Wow, with that much torque, and that much tire, there must have been a ton of twist on those rear rails to cause a stress crack. It almost looks like the welding in of the 4-link may have weakened the frame rail and made it brittle along the weld edge.
If it were me, I would think the best way to repair would be to get the cars weight supported so that the cracks close up and then re-weld the crack. I would then probably section out the outside of the frame rail and add steel to the inside of the channel to re-inforce the rail. After that, close up the outside of the rail and maybe add another plate of steel to match the rail profile and give it some more thickness.
Without removing the 4-link, the access is pretty limited. Grafting in heavier rear frame rails might be in order during the off season.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
  #2212
Old 06-18-2011, 07:28 PM
BTW --- Welcome to the world of high horsepower and big sticky tires... on 42 year old metal. The too high of heat caused "carbonization" of the base metal... in other words - it became brittle.....
It's really not uncommon nor is it a "big deal" now that you've discovered it. Just make sure you go to a REAL chassis shop that knows how to weld stuff correctly. Lots of people can stick two pieces of metal together -- but that ain't all there is to welding.
  #2213
Old 06-18-2011, 07:32 PM
skatinjay27's Avatar
just get some beefed up art Morrison frame rails in there!!!!1
what greg and mock said above will be good to go.
no way it was solely the drag racing... seeing your 60s you didnt hook hard enough to cause that instantaneously, im sure its been a slow process. by the location of the crack you can deffinatly tell it was weaken due to the bracket being welded in...
as far as having someone local do it, Im pretty sure russel still does work at his home shop and for your anal azz he's the only person local i can think of that will work for you. call curtis i think he has his contact info.
AJ
  #2214
Old 06-18-2011, 08:42 PM
Wow. Now you've gone and done it .
for those pre-race inspections. I'm guessing those don't happen enough for many people. This is a good reminder for everyone.
John
'71 Nova (Build thread)
FFR Roadster
  #2215
Old 06-18-2011, 09:36 PM
I was actually kind of proud of myself. I've always kept a close eye on the rear frame rails. They are original and in very good shape but I was never impressed with the welding that holds the cradle in the car. It's definitely happened within the last 2 events. I get on a creeper and go from nose to tail with a flash light on a regular basis.
John is absolutely correct. It's very important to stay on top of these cars, especially when you run them at the limit like I do. 6000 miles and over 20 races. I'm not surprised but glad I found it before my trip to CA next month.
Thanks for the advice guys. Maybe I'll swing by Ironworks on the way to the event. I wanted to drive the car, but I may end up just trailering to Ironworks and having them fix me up and on my way. If I can't find someone local I trust, which is not likely at this point. Greg, I was thinking the same thing. Tie it into the cradle.
  #2216
Old 06-18-2011, 09:42 PM
coolwelder62's Avatar
That sounds like the best way to handle it Todd.the crew at ironwork's can fix correctly.
  #2217
Old 06-18-2011, 09:52 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Damn that sucks man, hope you get it fixed soon!
WicKeD
  #2218
Old 06-19-2011, 02:46 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Yeah...I'm like 8000 mile from home. Cell reception in this sh!t hole isn't going to happen. But I have the internet thankfully. Here's the number I have for Russ. 285-4211 He's the only local guy I know of and you know he does good work.
Best of luck buddy.
Curtis
  #2219
Old 06-19-2011, 03:57 PM
ironworks's Avatar
Clean it - grind it out a bit so it's clean - weld it up - then FISH PLATE it.... I'd tie into the crossmember - which is the origin of the crack. That crossmember was welded with too much heat and caused the metal to become brittle right next to the weld area. Poor welding - plain and simple.
Don't ask how I know. But we worked on a car with the same issue, only worse. The problem is the brackets are alot thicker then the stock frame rail material. And when you weld it in it needs more heat on the thicker material to make it actually penetrate the thicker stuff. Those parts are actually designed to be bolted in and one of my customers who has an engineering masters degree and a degree in welding inspection looked at the car here at the shop and said it might not have broken had we just bolted it in. CRAZY?? So on said car we just plated the outside frame rails with 1/8inch plate to spread the load over more of the rail.
Let me see if I have some pictures
  #2220
Old 06-19-2011, 04:03 PM
ironworks's Avatar
It cracked right next to the weld, there is some fancy word about embrittlement issues that goes with what happened with old metal and new and heat embrittlement blah blah blah.
But at the end of the day, when you beat on cars they just break sooner then later.
Closed Thread
