Old 11-14-2013, 09:10 PM
INTMD8's Avatar
INTMD8 INTMD8 is offline
59 is collecting dust, still waiting on motor and trans
Finally accomplished something on the 57! As mentioned, I'm re-doing a few things I've already done once, or twice.
I first made the turbo system by modifying 2010 camaro cast steel manifolds, which I was happy with until the new ZL1's came out with cast stainless manifolds, so I had to rebuild them. Fixtured the first set so I didn't have to start from scratch as far as placement of the flanges. This thick stainless is not easy to work with but they are finally (roughly) finished.
Still need tons of sanding as I plan to have the manifolds/turbine housings/downpipes polished.
69 Charger. 438ci Gen2 hemi. Flex fuel. Holley HP efi. 650rwhp @7250 510rwtq @5700. 95 F355. 96 Carrera 4S. 59 Cadillac series 62 convertible.
Old 11-15-2013, 04:51 AM
Rick D's Avatar
Rick D Rick D is offline
Nice Jim!!
As for the 59 I could have finished it already you know
Rick
Old 11-15-2013, 05:24 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
that's one BAD Caddy,nice work so far
Old 11-15-2013, 05:27 AM
Fitz78ta Fitz78ta is offline
I love the manifolds man. I had no idea the ZL1's were stainless. Those things are gonna look killer all polished up.
What accessory drive do you have?
Project:
1978 Trans Am - Twin turbo Iron block 370 LS1
All fabrication done by 417 Motorsports
https://lateral-g.net/forums/showthread.php4?t=30588
Old 11-15-2013, 06:23 PM
INTMD8's Avatar
Thanks guys.
Rick, I know, but then I would have to pay for it which at the moment would be a problem.
The accessory drive is Wegners. Decided I needed a bigger compressor to run the dual A/C systems so they put this system together. 8-rib as well, very nice.
Old 11-15-2013, 08:06 PM
FETorino's Avatar
FETorino FETorino is offline
This build just keeps upping the ante.
Rob in SoCal
Old 11-30-2013, 06:02 PM
INTMD8's Avatar
Like most everything else I've done, I decided to rebuild the floors that I boxed in around the frame.
The floors to either side of the frame were beat up a bit and also there wasn't much room for your foot on the outboard sides. Soooo, I cut it all out and started over.
The Baileigh brake and bead roller work awesome. The ancient band saw is kicking ass as well. Not sure how I survived without this stuff.
Old 11-30-2013, 08:05 PM
65 347's Avatar
65 347 65 347 is offline
Looks great, love the craftsmanship!
Mike
Old 11-30-2013, 08:45 PM
Mike
Me too!
Old 11-30-2013, 10:57 PM
Beebe's Avatar
Beebe Beebe is offline
From the looks of the motor build , you might want to buy some stock in tire manufactures ... lol
Love it !!
Known as "BEEBE" on Performanceyears , Pro-Touring , TAC and others.
