Old 11-10-2019, 11:08 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Wow, having the car on a rotisserie sure looks like a good way to set up a suspension and weld all the brackets from a right side up position. Do you have to notch the rear frame rails for a pocket to accept the front of the lower arms?
Ric
2002 S-10, Daily Driver and autoX
1966 Chevelle MALIBU ( mine since 1971) Drag car converting to a track car!
Old 11-11-2019, 05:47 AM
Gmachine1911's Avatar
Gmachine1911 Gmachine1911 is offline
Coming along great, Joe! Cleco pins are one of the best things ever invented!
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
Old 11-11-2019, 08:39 AM
jarhead's Avatar
jarhead jarhead is offline
Yes I am measuring to see if I can put pockets in the original frame rails and reinforce the outside of them. I have been looking at how SpeedTech manufactures their extreme chassis, that looks like a great option on making the pockets. I want them to be inside the frame rails rather than on top with sandwich brackets if that makes sense.
Thanks Shane!
joe
Semper Fi
My 68 Torino
Old 11-13-2019, 10:05 PM
TAC TAC is offline
Wow. you have been hard at it Joe. Good to see all the progress.
71 bronco...fully custom built...daily driver
69 Torino...to be built
gary
The Following User Says Thank You to TAC For This Useful Post:
jarhead (11-14-2019)
  #225
Old 11-14-2019, 03:30 PM
jarhead's Avatar
More work the last two days.
Had to remove the temporary supports I had holding the housing. I didn't have enough steel on hand so I used a couple of old lawn tractor blades
I ordered some spring perches so I could drop it down a little farther to mock-up trailing arm clearance.
A couple more days to work on it then I am off to Austin to see my daughter/ We are taking a sheet metal class at Hammerfab next week.
joe
Semper Fi
My 68 Torino
The Following User Says Thank You to jarhead For This Useful Post:
waynieZ (11-17-2019)
  #226
Old 11-16-2019, 12:56 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Joe, did you ever get the wheels in? Let's see pics if so....
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 11-16-2019, 02:26 PM
jarhead's Avatar
Not yet, have to finish paying for them Dec 2nd.
Larry and Zak are awesome to deal with. They allowed me the time (weeks and weeks) to get the measurements right.
I agonized over the measuring , built jigs, built supports for a 9" housing, had a friend come over and double check all my measurements.
Going with titanium centers and brushed barrels.
joe
Semper Fi
My 68 Torino
Old 12-09-2019, 06:53 PM
jarhead's Avatar
I got the housing setting on some square tubing that is tacked to the frame rails and on top of actual spring perches. I got it as low/high as I think it will be for bottoming out.
I then was able to get it all squared up and centered so I mad some templates out f cardboard, then hardboard. I need to get these dialed in and have four of them plasma cut.
more fiddling ahead
joe
Semper Fi
My 68 Torino
Goosesdad (12-10-2019)
  #229
Old 12-09-2019, 07:40 PM
Looking good Joe.
The Following User Says Thank You to waynieZ For This Useful Post:
jarhead (12-20-2019)
  #230
Old 01-28-2020, 03:29 PM
jarhead's Avatar
The trailing arm plates are now cut and ready to weld on the passenger side. Looking forward to getting it on the ground. #speedtechperformane torque arm.
joe
Semper Fi
My 68 Torino
The Following 4 Users Say Thank You to jarhead For This Useful Post:
camcojb (01-28-2020), dhutton (01-28-2020), Sonar Chief (01-28-2020), waynieZ (01-28-2020)
