Old 07-16-2012, 06:02 AM
ma73z's Avatar
ma73z ma73z is offline
Originally Posted by 67XR7 View Post
HEY Mark, where do you buy all your wiring blank plugs and etc.? I'm still using GM weather pack stuff but sometimes I need more then 5-6 slots.
I'd also like to know where to buy them.
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
Old 07-16-2012, 06:52 AM
JMitch19's Avatar
JMitch19 JMitch19 is offline
I can't answer for Mark, but the company I work for does some GM harness work for the aftermarket. We have found powerandsignal.com to be your best bet for higher quantity orders and mouser.com to be the best for low quantity.
Jason Mitchell
1971 Camaro 416 LT1 Project
Old 07-16-2012, 07:16 AM
HEEP's Avatar
HEEP HEEP is offline
So, from what I can see, Mark keeps an extra sub frame in the garage just in case?
The wiring is fantastic. I wish I could do this type of detail.
HEEP
Old 07-16-2012, 04:30 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by Jtomas801 View Post
Hi Mark,
Did D&D performance do any tricks on the inside of the transmission, or is it stock from the factory? Also I see an oil pump for the trans, are you just using the fill and drain ports to remove the oil or is there some sort of spray bar in there?
The car is coming along nice hopefully I will be able to see it in person one day.
Thanks,
Jon
D&D Perf said the TR6060 is good as is.
We are using a Weldon oil pump to run the oil to a cooler and sucking out of the drain and returning into the fill port.
Mark
Old 07-16-2012, 04:32 PM
Stielow's Avatar
Originally Posted by JMitch19 View Post
I can't answer for Mark, but the company I work for does some GM harness work for the aftermarket. We have found powerandsignal.com to be your best bet for higher quantity orders and mouser.com to new the best for low quantity.
We get most of the connectors from Mouser and some from GM service parts.
Mark
Old 07-16-2012, 04:41 PM
Stielow's Avatar
HEEP
I have another '69 in the wings to be built.
Mark
Old 07-16-2012, 04:44 PM
HEEP's Avatar
I've watched your builds since I joined this site. I figured you had something. I've been planning my Chevelle for 20 something years. you can build more cars than 'I can plan. Thanks for giving us these updates. I learn something everytime I see a post.
HEEP
Old 07-16-2012, 05:56 PM
next69 next69 is offline
Mark, do you have any plans for a Nova? I thought I seen something years ago that you owned the 72 Nova that W2W turned into the Super Sleeper.
Old 07-16-2012, 07:29 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Oh man, a Stielow Nova would be effin' sweet!!
Jeff-
Old 07-16-2012, 07:31 PM
carbuff's Avatar
carbuff carbuff is offline
Mark,
From the pictures, it appears that you are running the stock bellhousing, unless that was just for mockup. Is that correct? At the power levels you are making, do you not think you would want something stronger? Or is your opinion that the stock bellhousing would be sufficient in case of a clutch failure?
Also, on your transmission cooler, I don't know what transmission temps are supposed to be, but I think I just read that the Weldon pump is thermostatically controlled. Is that correct, and do you run within that window, or do you control/override it somehow?
Finally, what size lines are you running to/from the trans cooler? I would think that a heavy weight oil like that would need larger lines, but I think I read that the pump is set up for -6AN lines?
As always, appreciate the education!
