Old 02-17-2013, 01:20 PM
Flash68's Avatar
Flash68 Flash68 is offline
the whole experience is just the polar opposite of driving something "normal".... which is exactly what I like about it!
Originally Posted by Cris@JCG View Post
I have a C&R unit that has a Tru Trac in it with the internal pump .. No problem on the replacement of the locker
Now why would you get a unit like this.. a built in pump for cooler & not run it..
[/IMG]
Because it may not be necessary. My diff temp gauge will tell me what I need to do.
I like to add things only if necessary... you know, like a big SB2.2 engine.
Originally Posted by carbuff View Post
Good to know...
Cris,
Does that cooler get much airflow? Tucked up against the gas tank like that, it's hard to see how much air would get through the fins? Or is the cooling in this case less about flow and more just about surface area to dissipate the heat? You aren't running a temp gauge on the diff, are you?
I can't see why one would install a system like this and not monitor temps. I'll surely run a diff temp gauge.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 02-17-2013, 06:46 PM
carbuff's Avatar
carbuff carbuff is online now
Where does one install the temperatur probe for the differential? I presume it needs to be at or near the bottom to stay 'in' the fluid... I'm not sure if I've seen one before...
Old 02-18-2013, 01:50 PM
intocarss's Avatar
I'd bet you can attach it to the out going line to the cooler
Old 02-18-2013, 01:56 PM
carbuff's Avatar
Agreed, but in Dave's case, and more importantly, mine , we will neither have coolers, at least to start. So I was wondering, if I wanted to run a gauge to monitor the temps to decide if I need a gauge, how I would go about it?
Old 02-18-2013, 04:29 PM
intocarss's Avatar
OH didn't realize you weren't running a cooler :sieg
Old 02-18-2013, 05:29 PM
Flash68's Avatar
I did some lookin around and drilling/tapping a fitting into the bottom half of the carrier cover looks to be a common method.
2014 4 tap Keezer
Old 02-18-2013, 05:31 PM
WELD in a proper bung.....
Old 02-18-2013, 05:36 PM
Flash68's Avatar
I didn't say it was gonna by MY method.
You got me. WELD is the key word there.
2014 4 tap Keezer
Old 02-18-2013, 07:11 PM
carbuff's Avatar
That's what I assumed, but I'm iffy on the idea of a sensor hanging out the bottom of the housing. I might have to reconsider one of my gauge choices though if I'm going to do enough road course events.
Thanx!
Old 02-20-2013, 11:08 PM
Flash68's Avatar
Thanx!
I hear ya Bryan. This could be an option?
https://www.pegasusautoracing.com/pr...p?Product=1227
2014 4 tap Keezer
