Old 10-10-2013, 01:50 PM
MX145 MX145 is offline
Seems like forever since my last post. It's been a busy end of summer. Sent my baby girl off to college, bought a new car, moving, works crazy busy, a few birthday parties, kids sports,.. Stuff you guys know all too well.
I plan to spend more time in the shop in November. I did however finish up the 4-link pockets. The rear ends in the car finally. I'm happy with how it turned out. The axle tubes are within .010 on the dial indicator now. Phew.. That was stressful. I never realized the factory 9" rear ends had such large tolerances. Mine was almost .050 out on one side before we started on it.
I should be hauling the car down to my dads in the next few weeks to throw on the lift and finish up the bottom side and mock up the engine and trans.
Old 10-10-2013, 01:59 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Keep updates coming,we like them
Old 10-10-2013, 03:06 PM
Here's some pics of the 4-link pockets. I second guessed myself at least half a dozen times on the design and location. Luckily I had Brendon to keep me straight.
Old 10-10-2013, 03:35 PM
I tweaked the rear end geometry and brackets so many times I lost count. After debating over and over and factoring in excellent advise from successful racers like Ron a Sutton and my dad I ended up settling for two different anti-squat configurations. One for road race and a second setup for drag. I'm not 100% sold on arch slotted brackets so I went with multiple holes. The pan hard bar will be slotted as the load is perpendicular to the slot.
Here's some of the brackets off the CNC mill.
Here's the round stock and bushings my dad turned in the lathe to be able to setup the rear end. We bolted the 3rd member into the housings with shims the same thickness as the thinner gasket to locate the bar which we used for reference with the dial indicator to check the housing ends before I welded them on. We reused the old ends and turned them down to make a step in the tube side to locate them on center. I took most of the pictures with my dad's phone. This is all I have at the moment.
Here's the spacers that go between the brackets and the heim ends. I used 5/8" heim joints with a 3/4" shank and turned and cut left and right hand threads in 1" .156 wall 1022 DOM tubing I picked up from Morrisons shop.
I set the wheel base to 108". 2 deg pinion angle with the holes in the outside brackets at 90 deg (vertical/plum) and the bottoms of the inner brackets at 0 deg (level)
Here's the finished width. I was barely able to squeeze the 11.5" wheels with 315's in there. The rear end articulates well with a rolled edge on the inside lip of the fender.
Old 10-10-2013, 03:43 PM
Hi Jeff. Good to hear from you. I was just checking out your updates yesterday. Your car helps motivate me. You're getting so close and man is it nice!!
Old 10-10-2013, 03:46 PM
Wheels look killer... I'd also recommend trying at least a 255 tire on there if you can.
You guys are right. A 255 will be the way to go. Gotta wear these out first though.
Old 10-10-2013, 03:52 PM
I installed the trunk lock and threw the front fenders back on to get an idea of the stance. . It's been a long time since I've been able to push this thing around on its own 4 wheels. It was nice to get it outside.
Old 10-10-2013, 04:03 PM
BTW Dave, what do you feed your cat? He looks to be a little intense.
Old 10-10-2013, 05:32 PM
tubbed69's Avatar
I like your wheels and the stance is real good,keep up the good work,really nice.
Old 10-10-2013, 06:36 PM
Thanks Jeff. The guys at Fikse did a great job for us! This new design will be available soon. I'm really happy with it. They've got a lot of good things going. New designs, more hoop choices and bigger wheel sizes.
