Closed Thread
Old 01-25-2024, 08:52 AM
dontlifttoshift's Avatar
I thought the 3rd pedal was the anti theft device.
Donny
The Following 2 Users Say Thank You to dontlifttoshift For This Useful Post:
130fe (01-26-2024), zz430droptop67rs (01-25-2024)
Old 01-25-2024, 09:14 AM
camcojb camcojb is offline
Old 01-27-2024, 11:23 AM
Stielow's Avatar
Stielow Stielow is offline
Default Hobbs Camaro (Old Drag Car)
More updates
D71267 upper hose
E71990 lower hose
Stielow Engineering
The Following 9 Users Say Thank You to Stielow For This Useful Post:
214Chevy (01-27-2024), 89 RS (01-27-2024), camcojb (01-27-2024), dhutton (01-27-2024), Goosesdad (01-29-2024), jmac (01-27-2024), Ketzer (01-27-2024), NAPA 68 (01-28-2024), srode1 (01-28-2024)
Old 02-03-2024, 02:12 PM
Stielow's Avatar
I was not happy with my first velocity stack. I decided to make a new one. Fun project where I go to use my shop.
A little cleaner. Not sure if it will make any more power but it seems better.
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
camcojb (02-03-2024), jarhead (02-08-2024), syborg tt (02-03-2024)
Old 02-03-2024, 02:13 PM
Stielow's Avatar
Stielow Engineering
The Following 6 Users Say Thank You to Stielow For This Useful Post:
DBasher (02-05-2024), fleet (02-03-2024), Goosesdad (02-08-2024), Roscoe03 (02-05-2024), srode1 (02-04-2024), syborg tt (02-03-2024)
Old 02-03-2024, 04:09 PM
Dodge383fi Dodge383fi is offline
Looking good.
Nice drafting set. That brings back a lot of memories.
-Ed
Old 02-04-2024, 05:04 PM
clill's Avatar
clill clill is offline
What could go wrong ?
Old 02-08-2024, 04:12 PM
Stielow's Avatar
A little hard line action
Stielow Engineering
The Following 4 Users Say Thank You to Stielow For This Useful Post:
214Chevy (02-08-2024), camcojb (02-08-2024), Roscoe03 (02-08-2024), WSSix (02-08-2024)
Old 02-08-2024, 05:54 PM
Very nice hardline work.
Old 02-08-2024, 08:44 PM
Blown353 Blown353 is offline
Mark, how do you normally run the brake hoses and wheel speed sensor wires to the rear axle for the ABS? Do you drop them all near the center section and run them along the axle like GM routed the brake lines on these cars originally, or you you drop each side down independently near the hubs like many late model cars with IRS do?
Just asking because I'm adding ABS to my car, and trying to decide how best to run things to the rear hubs and calipers. I'm leaning towards dropping both brake hoses and the speed sensor wires above the center section and then running them down the axle tubes to the rear hubs.
1969 Chevelle
Closed Thread
