Closed Thread
Old 08-29-2011, 09:20 AM
It's their 600 racing fluid. http://www.jegs.com/i/Wilwood/950/290-6209/10002/-1
I have a lokar throttle arm and sparco pedals. I'm not sure I can make it work either at this point. The lokar arm does move the pedal over closer to the brake pedal.
  #2432
sik68's Avatar
sik68 sik68 is offline
Hey Todd, you have the Lokar pedal too? I messed with the splines for days to get the height right but it wasn't coming out right, so finally just added ~5/8" thick worth of plastic sheets underneath the pedal pad. The spacing between pedals isn't so bad, it's the height offset.
Nice rubber!
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
  #2433
Old 08-29-2011, 09:25 AM
My thought is to get the brakes bleed back out so the pedal is normal and figure out the right height under max effort braking. Then I'll add a throttle arm stop to keep the stress off the throttle cable. I'm sure it's going to be tricky and doubt I get to it before buttonwillow. I'd rather have Dave's set up!
  #2434
Old 08-29-2011, 09:54 AM
Ron in SoCal's Avatar
'Liberal Ronnie...,' Gigg-ady!
So glad you finally came over to the aluminum darkside. Big Torque + fast R's = Title Contender! Also, +1 for the flywheel balance. I made the mistake of not doing it one time. Never again...
Ron in SoCal
69 Camaro in progress
  #2435
Old 08-29-2011, 10:55 AM
Track Junky's Avatar
I remeasured heights and wrote them down this time and these will be from floor to fender lip:
Passenger side front 22 1/2"
Passenger side rear 22 7/8"
Driver side front 22 3/4"
Driver side rear 23 1/2" Due to Fays 2 Watts link plate sandwiched under leaf spring/shock plate.
Gaetano Cosentino
  #2436
Old 08-29-2011, 12:17 PM
Do you have any shock travel left?
  #2437
Old 08-29-2011, 02:47 PM
Are you kidding??? With all that flex in my stock subframe.........I got tons
Actually, measurable travel up front is barely 3" and rear is probably a bit above 4".
I can gain travel if I relocate front sway bar above subframe like on the Penske/Donahue '69 but it hasn't been an issue yet with the 700 lb springs.
Bringing the hub out 2" with the spacer for the vette wheels may cause some issues due to increased leverage but I'm going to bring my Torque Thrusts out to Buttonwillow just in case.
Gaetano Cosentino
  #2438
Old 08-29-2011, 03:41 PM
intocarss's Avatar
Finally some pics of T Junkies car. I've been looking and could never find a thread about it. Looks great, More info please!! Sorry for the high jacking of your thread. Now back to the regularly scheduled program.
  #2439
Old 08-29-2011, 04:24 PM
Flash68's Avatar
Flash68 Flash68 is offline
I've got the Wilwood 600 fluid this time around. I cooked my front fluid in Fontana last month.
What fluid were you using before? This reminds me to upgrade that stuff.
Absolutely. People keep commenting on my track vids to use heel/toe... I welcome them to come try in my car. My height difference is so far off it's not funny.
Well yes you could cheat and join the really really dark side..... Todd, I am your father....
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
  #2440
Old 08-29-2011, 05:23 PM
Sorry for the hi-jack Todd.
Thanks for the kind words, I'll throw a little something together when I get a little more time.
Gaetano Cosentino
Closed Thread
