Old 07-08-2025, 10:14 AM
syborg tt's Avatar
Originally Posted by dhutton View Post
Sounds like maybe you could use a bit of a laugh…
Yes and that picture was perfect.
marty-mj
The Following 2 Users Say Thank You to syborg tt For This Useful Post:
camcojb (07-08-2025), dhutton (07-08-2025)
  #2472
Old 07-08-2025, 10:15 AM
syborg tt's Avatar
Originally Posted by Cramer4918 View Post
I’m so sorry to hear about your misfortune, Marty. It seems like when you get a couple steps forward, something jumps up and sets you back ten. Hopefully you can get it sorted quickly and without breaking the bank. Good luck to you!
I’ve been fighting this motor for years and I have finally decided to send it to the junkyard.
marty-mj
The Following User Says Thank You to syborg tt For This Useful Post:
  #2473
Old 07-08-2025, 12:26 PM
syborg tt's Avatar
This would be engine oil that leaks every time I start it.
More trans fluid going to waste.
Pulling the pretty pan off and plan to install a stamped steel pan.
Important pictures when your memory sucks.
Just making sure everything is plugged in.
marty-mj
  #2474
Old 07-08-2025, 12:34 PM
syborg tt's Avatar
Finally shortened this vacuum line.
When you have memory issues you need to take pictures of everything.
You have no clue how hard it was finding this little plastic cover.
I had to spin the jack around so I could support the motor when we remove the transmission.
Shocking we only spilled a little bit of trans fluid.
Daughters how and Remy can finally go in the house.
Love this crossmember from G-Force.
And it’s out !!
I’m still on the fence as to what I should do with it !
marty-mj
89 RS (07-13-2025), camcojb (07-08-2025)
  #2475
Old 07-08-2025, 12:37 PM
syborg tt's Avatar
Considering this motor.
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
camcojb (07-08-2025), Ketzer (07-09-2025), Roscoe03 (07-15-2025)
  #2476
Old 07-08-2025, 01:44 PM
fleet's Avatar
fleet fleet is offline
MJ,
I’m very sorry to hear that as well.
Thanks for updating us though.
Hey Skip
Well, I am back on it and the more I dig into the issues with the trans. The more I regret it.
So the trans is garbage and the Wagner motor is also junk. It’s leaking everywhere and the hypothesis is the a few of the rings are bad or broken.
I am going to pull the trans and give it to a different trans shop to look at it. Even though the I plan to buy a new engine and transmission.
If you look way back in the beginning of the build I used this set up to get the trans out.
Since the trans pan is beautifully powder coated I am going to put a stamped steel pan on for removal.
The Following User Says Thank You to fleet For This Useful Post:
  #2477
Old 07-09-2025, 05:26 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
A sink? Or in this case... a Urinal?!
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 07-09-2025, 08:49 AM
Panteracer's Avatar
Panteracer Panteracer is offline
Default 2nd Chance Camaro
Marty,
I hear you on the leaking... in my shop the boys say
all my cars leak... some way more than others.. no fun
My last pantera engine we found out that Quench on the motor
too tight, pistons too loose in the bores so a lot of blow by
It basically blew out any gasket on the engine
Going to use Moroso evac system on the new build
similar to what Drag racers use with a check valve
Like using a Vac pump but no room in my Pantera engine
bay for a real Vac pump
Hopefully you get this resolved as LS engines are not suppose to leak
Bob
The Following 2 Users Say Thank You to Panteracer For This Useful Post:
camcojb (07-09-2025), syborg tt (07-13-2025)
  #2479
Old 07-13-2025, 12:40 PM
89 RS's Avatar
89 RS 89 RS is offline
Thanks for the update, Marty. Hate to hear about the engine/trans...hopefully you will get everything figured out and move in a direction that you like. Keep us posted.
Corey
1989 Camaro RS
The Following 2 Users Say Thank You to 89 RS For This Useful Post:
camcojb (07-13-2025), syborg tt (07-13-2025)
  #2480
Old 07-16-2025, 07:10 PM
syborg tt's Avatar
Thank you and I hope so myself
Originally Posted by Panteracer View Post
Going to use Moroso evac system on the new build similar to what Drag racers use with a check valve. Like using a Vac pump but no room in my Pantera engine bay for a real Vac pump
Bob
Please keep me posted as I would like to hear more on Moroso system / set up.
I promise I will.
marty-mj
89 RS (07-26-2025), camcojb (07-16-2025)
