Old 11-25-2012, 06:07 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Thank you, Blazer!
I spent some time this weekend tweaking the front bumper even more. I think I'm finally set with the front bumper. I had to add material back to my lower bumper brackets as they seemed to be torquing it funny. It kept pulling the bumper to the left which made it go off center. Of course, getting the bumper finally set meant adjusting the hood again, and then that made the cowl panel not fit anymore, so I was back to square one with that. I had to hammer down my inner cowl panel to make the outer cowl panel sit level. Also, one corner is pinching so I had to trim it back. I'll weld it later.
I also started making my rear brake vents. So far I only formed some metal, but I will need to get the actual ducting I plan to use before I go further with it.
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 11-25-2012, 07:03 PM
Its looking good.
Old 11-25-2012, 07:12 PM
Tuske427's Avatar
Its looking good.
Thank you, Wayne!!
Old 11-26-2012, 08:49 AM
67rstbkt 67rstbkt is offline
Looking pretty awesome! I've been messing with my bumper as well. Getting closer, but I still have a few issues. Mostly the gap between the "beak" and the center of the bumper.
Rusty Bird Build Thread:
https://lateral-g.net/forums/showthread.php4?t=18566
Old 11-26-2012, 06:37 PM
Tuske427's Avatar
Thank you. Yep, I had that issue, too. To fix it I added material along the top of the bumper so I could reshape it to better match the contour of the hood.
Old 11-27-2012, 07:50 AM
Thanks for the tip!! I was thinking I should try adding to the hood, but I think I'll give the bumper a shot since it worked for you
Old 11-27-2012, 04:33 PM
Tuske427's Avatar
Cool. I actually modified both parts on my car, but, at least with the bumper it's pretty easy to weld, grind, and file. the hood is more sensitive with the thin sheet metal and if you add material- it has to look good form both the top and bottom side since the front edge of the hood is lifted and seen...
Old 12-09-2012, 07:28 PM
Tuske427's Avatar
I started to make my rear brake vents by welding in the scoops I made the other weekend. I used some metal rode to add thickness and strength to the quarter panel as I didn't want to leave it as a single piece of metal.
I hope to get the other side in next weekend.
Old 12-09-2012, 08:23 PM
KPC67's Avatar
KPC67 KPC67 is offline
The body mods are coming together nicely.
Kevin Carter
Old 12-09-2012, 08:24 PM
Looks good> Your move along now.
