Old 03-21-2020, 02:22 PM
JD67SS's Avatar
JD67SS JD67SS is offline
Matt is more than capable and does build cars without my daily interaction. On my stuff I know how I want it. We work and communicate very well. Sometimes we do it my way and often he has a better idea and we do it his way. In all the projects we have done together I can only think of a couple items that had to be scrapped because it did not work out. Early on Matt like to make things “street roddy”. I like think functional and OE looking. He nails that. Look at my Blazer and Lillard’s S15. Looks like a prototype GM build. Killer work and attention to detail.
Matt thinks thought the whole build. He and his guys are very talented. Usually project creep comes from me.
So to answer your question, yes I communicate with Matt daily because I’m a control freak. Does he need me to nope.
Thanks for your honest and straight forward answer. It helps tremendously.
Sled Alley is on my short list.
JD
The Following User Says Thank You to JD67SS For This Useful Post:
XLexusTech (03-21-2020)
  #252
Old 03-22-2020, 05:26 PM
jmac jmac is offline
What gas pedal are you using with the Modo Innovations plate?
Did you see they now have matching pedals for the brake and clutch? Very cool, thought of your car when I saw them.
John
My 1967 Camaro
Old 03-23-2020, 03:54 AM
Stielow's Avatar
Stielow Stielow is offline
John
I’m using the Gas pedal that comes with the GM crate engine harness. It was used in the first generation Cadillac CTS.
To get an OE look I use this brake and clutch pedal covers off a Solstice.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
Goosesdad (03-23-2020), jmac (03-23-2020)
  #254
Old 03-23-2020, 10:08 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Mark.... did you have to do any mods to the firewall in order to clear the high pressure fuel pump? Putting an LT4 in my 69 Camaro, DSE Sub, using the Holley motor and trans mounts. I know you developed these for Holley. Any input would be appreciated.
Old 03-23-2020, 02:37 PM
JON Q's Avatar
JON Q JON Q is offline
Mark explains the firewall mod on page 10
Old 03-23-2020, 03:01 PM
If you could, for everyone's future reference, refer to the post # at the top right hand side of the post.
Everyone's settings are different, for me, this thread is only at 9 pages...
Thanks!
My 1967 Camaro
Old 03-24-2020, 05:35 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
Thanks!
The post in question is #94
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
The Following User Says Thank You to Jimmy Sean For This Useful Post:
jmac (03-24-2020)
  #258
Old 03-24-2020, 11:57 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
https://lateral-g.net/forums/showpos...9&postcount=94
You can copy the link from the post number as well.
Instagram- camaroaj
The Following 2 Users Say Thank You to CamaroAJ For This Useful Post:
Jimmy Sean (03-25-2020), jmac (03-24-2020)
  #259
Old 03-25-2020, 08:46 AM
cwylie cwylie is offline
Do those fit the factory brake and clutch pedals?
Old 03-25-2020, 08:47 AM
Stielow's Avatar
After some trimming
Stielow Engineering
