Old 06-06-2020, 07:11 AM
Stielow's Avatar
Stielow Stielow is offline
Working on cleaning up the wiring on the LT5 crate harness. The LT5 uses 2 ECMs.
Lots of wires
Stielow Engineering
Old 06-06-2020, 04:25 PM
F'in mine's Avatar
F'in mine F'in mine is offline
I guess the 2nd ECM triggers the other new port injection system. How are they activated, engine rpm?
1969 Camaro SSRS
Simon
Old 06-06-2020, 06:44 PM
That's what I'm wondering, too, Simon. I didn't realize these engines had two ECU's
Old 06-07-2020, 04:21 AM
Stielow's Avatar
The 2nd ECM S53 is basically a slave ECM that drives the 8 extra Port Fuel Injectors. It is controlled by CAN messaging from the primary E99 ECM. The engine calibration lives in the E99 ECM.
This is needed because a LT5 has 8 Direct Injectors and 8 PFI injectors.
HP Tuners has cracked into the ECM so now you can tune it.
Stielow Engineering
Old 06-11-2020, 09:00 AM
Stielow's Avatar
More progress at the Dutchboys
Stielow Engineering
Old 06-11-2020, 09:04 AM
Stielow's Avatar
We got the emblems back from Advanced Plating. Nice parts!
Stielow Engineering
Old 06-17-2020, 03:39 AM
69hugger's Avatar
69hugger 69hugger is offline
Question for you...Are these stock emblems you simply had chromed, or were they custom made in a different size or font?
I ask because just yesterday I contacted a custom emblem manufacturer about having some valve cover medallions made with "LS-3" engraved on them. I was told LS-3 is GM trademarked, and they were asked not to reproduce it. I was shocked.
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 06-17-2020, 04:25 AM
Stielow's Avatar
We made them one off. Not sure if LS3 is copy righted or not. We just did it.
Stielow Engineering
Old 06-17-2020, 05:02 AM
69hugger's Avatar
Thanks Mark. I guess I need to find a "renegade" CNC guy. Any ideas where I can get a couple 3" x 1-5/8" CNC machined medallions made would be appreciated.
Bill
Old 06-19-2020, 06:20 PM
BDAZSVT BDAZSVT is offline
You might try Joel at https://www.jccustomscnc.com/
