Closed Thread
Old 02-03-2024, 02:13 PM
Stielow's Avatar
Stielow Stielow is offline
I was not happy with my first velocity stack. I decided to make a new one. Fun project where I go to use my shop.
A little cleaner. Not sure if it will make any more power but it seems better.
Stielow Engineering
The Following 6 Users Say Thank You to Stielow For This Useful Post:
DBasher (02-05-2024), fleet (02-03-2024), Goosesdad (02-08-2024), Roscoe03 (02-05-2024), srode1 (02-04-2024), syborg tt (02-03-2024)
  #262
Old 02-03-2024, 04:09 PM
Dodge383fi Dodge383fi is offline
Looking good.
Nice drafting set. That brings back a lot of memories.
-Ed
  #263
Old 02-04-2024, 05:04 PM
clill's Avatar
clill clill is offline
What could go wrong ?
  #264
Old 02-08-2024, 04:12 PM
Stielow's Avatar
A little hard line action
Stielow Engineering
The Following 4 Users Say Thank You to Stielow For This Useful Post:
214Chevy (02-08-2024), camcojb (02-08-2024), Roscoe03 (02-08-2024), WSSix (02-08-2024)
  #265
Old 02-08-2024, 05:54 PM
camcojb camcojb is offline
Very nice hardline work.
  #266
Old 02-08-2024, 08:44 PM
Blown353 Blown353 is offline
Mark, how do you normally run the brake hoses and wheel speed sensor wires to the rear axle for the ABS? Do you drop them all near the center section and run them along the axle like GM routed the brake lines on these cars originally, or you you drop each side down independently near the hubs like many late model cars with IRS do?
Just asking because I'm adding ABS to my car, and trying to decide how best to run things to the rear hubs and calipers. I'm leaning towards dropping both brake hoses and the speed sensor wires above the center section and then running them down the axle tubes to the rear hubs.
1969 Chevelle
  #267
Old 02-09-2024, 05:58 AM
clill's Avatar
Please remove the sticker from the crank pulley.
  #268
Old 02-09-2024, 06:41 AM
Stielow's Avatar
The rear brake lines run down the sides outside the frame rail.
The wiring comes off the ABS module as twister pairs. Goes through a bulkhead connector the interior. Those wire join the rear compartment wiring harness that has the tail light, fuel pump…
The rear wheel speed wires (twister pair) pass through to a harness on the rear axle. At the connector we swap from normal wire (twisted pair) to a tougher encapsulation wire that goes the wheel speed sensors.
The OE style encapsulation wiring is hard to find and I had to purchase 1000 feet of it to get some. Nice stuff.
I’ll get a photo soon
Mark
Stielow Engineering
The Following User Says Thank You to Stielow For This Useful Post:
Roscoe03 (02-09-2024)
  #269
Old 02-09-2024, 06:43 AM
Stielow's Avatar
It came from China…
Stielow Engineering
  #270
Old 02-09-2024, 08:39 AM
The Following 4 Users Say Thank You to camcojb For This Useful Post:
Che70velle (02-09-2024), Ketzer (02-09-2024), thedugan (02-09-2024), zz430droptop67rs (02-09-2024)
Closed Thread
