Old 02-10-2020, 10:52 PM
fleet's Avatar
fleet fleet is offline
Originally Posted by cjfirstgen View Post
Engine is assembled and wired. Most visible hardware replaced with ARP SS 12pt bolts. Have to come up with a 3d scanner and make some coil covers. Open to other ideas as well....anyone?
Have you reached out to Roadster Shop yet?
Maybe they’ve done some already...
Old 02-11-2020, 02:57 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Those gaps though….
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
The Following 4 Users Say Thank You to cjfirstgen For This Useful Post:
fleet (02-11-2020), Sonar Chief (02-11-2020), waynieZ (02-17-2020), WILWAXU (02-23-2020)
  #273
Old 02-11-2020, 06:56 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Daaaaaang!
Curtis
Old 02-11-2020, 07:01 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Wow!! Looks incredible. You can definitely see the light at the end of the tunnel now...
Brent
Old 02-12-2020, 07:01 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
I love it when a plan comes together...
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 02-12-2020, 07:09 AM
cjfirstgen's Avatar
Thanks guys....definitely having fun now seeing it all come together.
Old 02-15-2020, 11:34 AM
cjfirstgen's Avatar
What is going on here.....
Old 02-15-2020, 12:13 PM
Goosesdad's Avatar
Goosesdad Goosesdad is offline
I'm guessing something sweeeet!
Have a great day!
John
My Build Thread:
https://lateral-g.net/forums/showthread.php4?t=53320
Old 02-15-2020, 02:40 PM
cjfirstgen's Avatar
You guessed right...haha. Going away from the analog dash and mounting a Motec C1212 datalogger behind the dash. The box drawn is the viewable screen area. Allow me to get a little technical and maybe provide some insight for others considering and short stop the research like I had undertaken.
Fortunately I connected with Mercury Racing and Motec engineers to figure out my options and best direction. What led me to this was the CAN Bus signal coming from the Mercury Racing ECU. When someone goes with the Mercury Racing SB4 engine you have a few options. First the CAN signal is Mercruiser's Smartraft std from the ECU which is used in their marine applications that are plug and play with Lowrance, Garmin etc. Think large flat panels in the boats sold today.
1. Gauge packages from Livorsi are plug and play with Smartcraft data but not a great option for a car.
2. Obtain a Smartcraft to analog gauge convertor. Good option and certainly the cheapest but you can't take advantage of all the data coming from the ECU.
3. Obtain a Mercruiser Smartcraft to N2K (aka NMEA 2K) converter with is a standard CAN data signal in marine platforms. Great option but whose platform can read N2K CAN data? MOTEC is the only one that can from what I have found for off the shelf as they do have significant presence in marine applications. Then a programmer just has to map the signals using the ECU Protocol Group Numbers. Sounds simple right?
The C1212 or similar also has both analog and digital input/output's outside the ECU environment or CAN signal like trans and diff temp for instance or traction control. In addition the Motec datalogger provides track data, times, etc. As far as the display with their display creator you can create multiple custom gauge layouts. Expensive route to go but very versatile.
Hope all that may help others considering the SB4 engine.
The Following 2 Users Say Thank You to cjfirstgen For This Useful Post:
68454RS (02-16-2020), Goosesdad (02-24-2020)
  #280
Old 02-20-2020, 09:36 AM
cjfirstgen's Avatar
Vibrosolutions 2mm dampener
close ratio 2:29 T56 mag painted and 12pt SS ARP hardware.
Goosesdad (02-24-2020), waynieZ (02-25-2020)
