Old 06-08-2018, 03:21 PM
Ron Sutton's Avatar
Car Year & Model: 70 Ford Mustang Fastback
Competing in: Track Car & Occasional NASA TTU races
Front Clip/Suspension: GT Track-Warrior
Rear Clip/Suspension: GT Track-Warrior
Engine: Track-Warrior 3 LS7 700 HP
Trans: PPG Sequential Shift T56 6-Speed
Brakes: StopTech 14” ST60/ST40
Owner: Greg Weld
Builder: Randy Chastain – One-Off Customs
More progess = more photos ! We're on track with this car for initial testing in 20 days !!!
Steel wheel tubs
Dash with Autometer Digital Dash system, including data acquisition.
Front end, hood & doors mock up for fitment
* Reminder: This 70 Fastback is widened 6". 3" per side. Greenhouse (Roof) is factory width.
Ron Sutton Race Technology
The Following User Says Thank You to Ron Sutton For This Useful Post:
syborg tt (06-10-2018)
  #272
Ron Sutton's Avatar
Tilt & Telescoping collapsible safety steering column.
Here are the StopTech Brakes optimized by Ron Sutton
Old 06-09-2018, 06:27 AM
jlwdvm jlwdvm is offline
For the interior sheet metal work: do you finish welding the joints completely, or use seam sealer between the tack welds?
Old 06-09-2018, 10:16 AM
Flash68's Avatar
Flash68 Flash68 is offline
Originally Posted by Ron Sutton View Post
Greg's RSRT GT Track Warrior will be capable of 1:51-ish on the 3-mile Thunderhill track with crows nest & 1:41-ish at Sonoma. Greg being a rookie will be several seconds off that
No pressure Greg.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 06-09-2018, 04:03 PM
No pressure Greg.
I'm going to have to find faster friends......
Old 06-09-2018, 07:24 PM
Ron Sutton's Avatar
We think of them as "spot" welds, but yes, we use a seam sealer, specifically 3M Fire Barrier Silicone Sealant 2000+. See it HERE.
  #277
Old 06-10-2018, 02:13 PM
mfain mfain is offline
Absolutely awesome build! Can't wait to see it on track. ABS? Traction control?
Pappy
Old 06-10-2018, 08:58 PM
TrackMuscle TrackMuscle is offline
What is the total weight of the car wet with no fuel? And as Pappy asked above, any ABS?
Old 06-10-2018, 09:42 PM
craig510's Avatar
craig510 craig510 is offline
Please keep an eye on the T/C Rods on the lower control arms. The bend in them makes me nervous. They will be under compression under braking which puts a large bending moment on them and they are pre-yielded from the bending process.
With enough wall thickness and yield strength they could be fine but it is something to watch. If you have trouble with your caster alignment changing they could be bending further.
Old 06-11-2018, 09:23 AM
Ron Sutton's Avatar
Pappy
Hi Pappy. No ABS. No Traction control. The only assist is the "no lift shift" for the sequential gear box. So the Driver has to "drive" it.
