Old 08-09-2013, 01:36 PM
Nick.V70's Avatar
Nick.V70 Nick.V70 is offline
Pretty spiffy looking!
Nick's 1970 Chevelle project - '70 SBC 383 Stroker - Rushforth Rated X wheels - 14" Wilwood - Anvil Carbon Fiber hood/deck lid - Fesler billet - Corbeau Sport Seats, and still building....
YouTube & Chevelle pics - Instagram @nick.v70 & @ChevelleFactory
Old 08-09-2013, 02:45 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Is anyone else concerned that those plug wires aren't stout enough?
Old 08-09-2013, 02:53 PM
Ron Sutton's Avatar
Was that sarcasm?
Ron Sutton Race Technology
Old 08-09-2013, 02:55 PM
Ron Sutton's Avatar
I apologize in advance if the answer is in your build thread.
I'm assuming you didn't keep the "Cup" camshaft. So what did you do for cam profile & type ?
Old 08-09-2013, 03:25 PM
Flash68's Avatar
Flash68 Flash68 is offline
Originally Posted by Ron Sutton View Post
Was that sarcasm?
Ron, you will meet Doug one day and you will understand.
No worries. This thread is a quagmire for sure.
It was not a cup camshaft to begin with. I purchased the motor used and we decided (were forced to) fix or redo quite a bit. The cam that came with it (Bullet) was in good shape and had pretty decent specs (but not ideal) so we are starting out with it. The plan is to upgrade the cam after my 2-3 year refresh (depending on usage) and rev it higher. But first thing's first....
Here are the specs:
264/274 @ .050
.390/.390 @ lobe
.663/.663 net lift with 1.7/1.7 rockers
113 LSA
This cam with the motor mostly as is (minus the head work, dry sump, E85) "supposedly" made 730 something hp below 7000 rpm and 610 or so ft lbs at around 6000 rpm.
We will know soon enough.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 08-09-2013, 03:48 PM
DFRESH's Avatar
Was that sarcasm?
No, of course not.
Old 08-09-2013, 04:00 PM
Ron Sutton's Avatar
Here are the specs:
264/274 @ .050
.390/.390 @ lobe
113 LSA
Wow, our engines have a lot of similarities ... but with unique differences.
My engine makes 730hp at 7000 rpm & 600# of torque at 5600rpm ... cam is 265/274 @ .050 & .648"/.630" net lift ... and also runs on E85. But mine is 405" on 23° degree heads.
What cubic inches is yours?
Old 08-09-2013, 04:13 PM
sik68's Avatar
sik68 sik68 is offline
You going to take it easy on the pulls, or are you gonna play hungy hungry horsepower?
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
Old 08-09-2013, 04:14 PM
Flash68's Avatar
Wow that is dang near the same huh. Those are great numbers for a 23* motor. What heads do you use?
But with my head work and mods I should be upper 700's I am guessing? If I hit the magic 800 I will be stoked.
My cubes are 437. 4.17 x 4.00
2014 4 tap Keezer
Old 08-09-2013, 04:20 PM
Flash68's Avatar
Ha now that trumps my cat avatar for sure.
Mike doesn't chase hp on the dyno he says.. and the dyno is for making sure everything runs properly. We will just play with timing, jetting, and carb spacers.
Another of his lines is "it's gonna make what it's gonna make"
so hopefully that = FE power + a lot more.
2014 4 tap Keezer
