Old 06-23-2014, 06:09 AM
ccracin's Avatar
ccracin ccracin is offline
That's awesome Ron. Just remember, all the wrenching now is making it better, not making it a car!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 06-23-2014, 07:04 AM
Sieg's Avatar
Sieg Sieg is offline
Good decision Ron
Old 06-23-2014, 07:49 AM
Answer the question.... did the zip ties help with the notchy steering issue...
Did you find the car pushing or oversteering? And were you able to dial it differently?
Matt changes or rebuilds his motors after every autoX - will you get more than one weekend out of yours?
Old 06-23-2014, 09:09 AM
Ron in SoCal's Avatar
Cool Beans Ron
Thx JD!
And another conehead is born!!
Be careful Ron, it is addicting... Glad to see you made it out and are driving the car like it was built to be driven.
It is an addiction. So fun Lance!
I know Chad! The car part lasted 300 miles. Now it's zip ties and car parts in my travel bag (the tool box was full, lol).
Good decision Ron
Thx Scotty. I couldn't resist!
Ron in SoCal
69 Camaro in progress
Old 06-23-2014, 09:13 AM
OBeer-WAN-Kenobi's Avatar
Cool!
I'm glad you were able to get it out and run it through it's paces a bit!
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 06-23-2014, 09:48 AM
Sort of. Notchy did not go away. It made the steering more PS assisted, but it still would fluctuate which is very frustrating, and on a big track not safe.
The way I'd describe it is you'd go into a turn, it was heavy than light or vice-versa. Then the car would be slow to turn, all the while moving forward/more tuning notes below, then it would react and sometimes SNAP and then I was left over correcting. It was very frustrating, but it's fresh and needs major sorting.
Plowed like a MF'r. Snap over steer above and springs were too light in the rear so it squatted with little throttle input and lifted front wheel weight bias. Early in the day it just skating all over the place. We made three shock adjustments before lunch (maybe went the wrong way once) and disconnected the rear bar. One adjustment after which made the car steer better; by that I mean we dialed out traction in the rear so the front could do its job. Then the problem was it plowed to the point that the tire was rolling over on itself and really not steering. There was no trail braking on this course or with this set up.
Honestly, we could armchair quarterback the day for hours but really the car (and then my driving) needs sorting. Most new builds do.
Well, at least the motor survived. That was the strongest thing going yesterday.
Originally Posted by cosmo meant it View Post
Ron,
Not exactly the kill story we've been led to believe would be forthcoming, but all in all it was a good first test 'for us'.
...the Rontourage got a little too 'involved'.
Quick story: there were lots of SCCA people there yesterday. One gal was named Rita. Rita has a C5, maroon paint and factory chrome wheels. She looks like your great aunt that's 15 years past retirement. She asked me to adjust her tire pressure between runs. I check her pressure and they're spot on for where she wanted them to be and she goes and busts out a 33.9. Next she has me take out 5lbs fr and 4 lbs rr. She pulls off a 33.4. Turns out she's been running SCCA for 40 years! (I could be wrong on the years, someone mentioned it)
I remember when BBalls was fresh and Mary drove it @ RTTC. It had a major push and they disconnected the rear bar, only to have mediocre results for the day.
Matt's been AutoX'ing his car for almost five years and gets almost as much seat time as anyone (almost). You look at all the top dogs and they're what, 10, 20 or 40 (Rita) years into it. That's a lot of seat and car set up time.
Ron in SoCal
Old 06-23-2014, 10:51 AM
#1 question.
Did you have fun? Who gives a sh!t about the rest of it. You learn - you try - sometimes you cry... at the end of the day if you can't remember what you did except that it was a blast... PERFECTION.
I've been saying for a very long time - but nobody listens to me..... Have one of the top drivers run your car thru 3 times.... That time is what you strive for if you do absolutely NOTHING to the car.... just fix the driver. When you get near their time -- now you start to tweak the car with some pro input.
Obviously this is a big picture look/statement. But if the car doesn't change and a good driver rips off 5 or 6 seconds faster than you're running... then there is 5 or 6 seconds in your driving that needs "work" if you do nothing to the car. The car might be a total piece of crap -- doesn't matter -- driving IT properly for the way it's set up is worth 5 or 6 seconds.
Of course getting it somewhere driving decently will also help you learn to be better.... so I'm not discounting the car set up. It's just interesting "bar" to set with a good driver at the wheel to see where you are at versus what's possible doing nothing at all. And they might get out of the car and tell you to do X. Just remember that X is for their driving style and not the guy parked two rows over that is just as fast but likes his car set up differently. Mike likes loose - Brian loves tight... I'd like to be able to drive anywhere within 10 seconds of either one. LOL
Old 06-23-2014, 10:52 AM
The power steering issue I'd be looking at -- belt slippage.... or air entrapment...
Old 06-23-2014, 11:04 AM
mmmmmm..... "Entrapment".....
'69 RS Camaro
Old 06-23-2014, 11:19 AM
fleetus macmullitz's Avatar
That sounds like a full day Ron.
Nice you have a job you can go back to and get some rest.
