Closed Thread
Old 04-29-2012, 09:51 PM
****, I have no secrets. There has never been a reason to change the cam. Pettis nailed it.
I did pull the top end apart, pull the intake, and inspect all the lifters tonight. I was about to lose the lifter on number 6 exhaust. The roller is sloppy but all the needles are in tact. Magically, it was one of the two lowest spring pressures. I dodged a bullet.
  #2832
Old 04-29-2012, 09:55 PM
Track Junky's Avatar
Glad you caught it before it was to late.
I'll give you three guess's at my duration @ .050
Gaetano Cosentino
  #2833
Old 04-29-2012, 09:57 PM
sixnina's Avatar
sixnina sixnina is offline
Thumbs up
Todd that's awesome that you caught it.Is there routine maintenance schedule that you follow on checking major parts or just something you do after giving her a hard beating( the car that is). Shane
Old 04-29-2012, 10:10 PM
intocarss's Avatar
I'll give you three guess's at my duration @ 50
Ok I'll bite. But first..Do you use Viagra??
TODD, good thing you caught that lifter, they eat up the insides if they let go, been there done that.. Also I believe that not just the roller bearing takes a beating on a R lifter but the whole body itself. I never trusted rebuilt lifters, but that's just me and my eng builders opinion.
  #2835
Old 04-29-2012, 10:11 PM
Way to much.
That's a tough question. I really think you have to find your own maintenence schedule based on your own abuse and use. Jason and I had discussed me doing all these things this Fall and he thought it was fine. I really don't think he realizes the extent I'm using the car. I got lucky, it was to long on a solid roller in a big block chevy. That being said, some guys could go a decade until they get to this point.
I can tell you this, if I keep up the schedule I've been runing for the last 3 years, it will get valve springs every year. I'm sure there on some LS guys chuckling right now. I've seen a fair share of them scattering all over the pavement over the last couple years. Anytime you get away from stock specs, you lose stock reliability. This is a lesson for everybody that is abusing their equipment.
  #2836
Old 04-29-2012, 10:13 PM
F-me. Anybody else want to hop on before the train leaves the station.
Gaetano Cosentino
  #2837
Old 04-29-2012, 10:14 PM
Thanks Jerry. I'll talk to Jason about that. That was already swimming around in my head.
  #2838
Old 04-29-2012, 10:15 PM
Not happenin....
  #2839
Old 04-29-2012, 10:25 PM
intocarss's Avatar
Also ask Jason if he believes that.. very low RPM or idling kills SOLID roller lifters faster, They tend to bounce and that does more damage then high RPMS. And for what it's worth I ran Crower SS rockers and stud gurdles seeing RPM's as high as 8500 over and over and never had an issue and my valve adj stayed very true also
  #2840
Old 04-29-2012, 10:26 PM
FETorino's Avatar
FETorino FETorino is offline
Solid rollers were meant for racing where you tear things down and check them periodically. You did the right thing.
My builder said 10k mi max then throw them away and buy a NEW set.
Rob in SoCal
Closed Thread
