Old 07-22-2013, 11:26 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Default new stance, lower roll center
From inspiration after reading Ron Sutton's post about chassis and suspension in Rob's thread, I also lowered the car 1.5" in the front and 1.0" in the rear to lower the roll center as much as possible... if your reading... thanks for the great info Ron. I will have some questions in a future post to ask about front and rear shock compression and rebound dampening settings.
I lowered the car as much as possible... while maintaining functionality with no rubs while cornering.
New measurement from floor to front fender lip, 23-1/4"
New measurement from floor to rear fender lip, 24"
New stance after lowering
Rear set up is Global West reverse eye 2" drop Cat-5 leafs with a 3/4" spacer between the leafs and axle. The front set up is Global West tubular A-arms with 600lb coils cut to 12" length.
The sub frame is now 4-1/4" off the ground, and the headers are about 3-3/4" off the ground.
So far no tire rubbing or scraping.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 07-23-2013, 03:00 AM
Gil's Avatar
Gil Gil is offline
Awesome thread, build, skills, car, stance... for sharing
Gil
Old 07-23-2013, 12:21 PM
PTAddict PTAddict is offline
Originally Posted by DaleTx View Post
I have been driving the car with the new leafs for a couple of weeks now. Major improvement... the car does not squat on acceleration... hooks up much better... and feels way more stable in corners. I will be doing another track day in two weeks and I can't wait to try out the new set up.
Thanks again on the good advice guys.
Nice write up and pics. Good to hear they're working out for you so far.
Just a note of caution for those of you doing street-only builds: the ride these springs give is, uh, firm If you're doing a lot of just cruising, on less than perfect roads (hello, Michigan) these might not be the ticket.
Latest car: https://lateral-g.net/members/borduin/
EFI Tuner for: http://www.modernclassicsauto.com
Old 07-23-2013, 02:14 PM
Flash68's Avatar
Flash68 Flash68 is offline
Dale that is a great write up and glad those Meow-5 leafs are the ticket for ya.
Lookin fwd already to your next track day video.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-23-2013, 06:36 PM
Sieg's Avatar
Sieg Sieg is offline
The Cat-5's should help keep him out of the kitty litter.
Old 07-23-2013, 09:05 PM
DaleTx's Avatar
Gil
Thanks Gil... appreciate the compliments!
Thanks Scott... you were right about these leafs, they work great. The car hooks up much better now, and feels very stable cornering and accelerating. I will be out at PIR in a couple weeks to try them out, maybe I'll see you there.
Thanks Dave... I'm hoping to come away from the next track day with some compliments from Sieg after watching the video... rather than him telling me how slow I am, Lol.
Lets's hope so!
Mario Andretti
Old 07-23-2013, 09:49 PM
Sieg's Avatar
HEY! I wasn't telling you how slow you were, I was telling you how to get FASTER!
Old 07-23-2013, 11:49 PM
MX145 MX145 is offline
Haha! That's awesome!
Dale, you're not messing around. You got right to it. Rons a huge contributor. He's got me thinking or rethinking things as well. Great job on the mods and thanks for sharing the specs. Your car looks great! Can't wait to hear how your next track day goes.
Old 08-06-2013, 11:42 PM
DaleTx's Avatar
Thanks... I've been following your build to. The supersonic blue color will look great on your car.
On Monday this week I met Scott Bourduin out at PIR while he was there running a track day with the Corvette Club. After we chatted for a while Scott invited me to ride along for his final session of the day. I jumped at the chance and it was great to ride along and see what lines he drove... where he braked and so on... it was a great learning experience for me.
Scott's driving ability and car are very impressive to say the least. Thanks to Scott for letting me ride along! I am signed up for a track day at PIR on Friday and I plan to push the braking a little further after seeing how Scott ran the track.
A couple shots of Scott's car at PIR (from my cell phone)
In preparation for my track day this Friday... I put new brake pads on and greased the front wheel bearings on my car. The brake pads are Baer decelerator ceramic matrix pads. These pads work great and have a good feel.
Next I pulled the front hubs and greased the front wheel bearings.
I also revised my design on the cold air intake that goes from the 4 barrel TB to opening in the cowl hood. I dropped it down slightly so I could get additional clearance from the top of the air cleaner to the top of the tunnel on the cowl hood, and I went to a foam seal rather than the rubber tube seal I had before. I think this looks cleaner.
The new set up installed in the car. You can see the IAT sensor mounted in the back... this works good.
When I switched to the LS engine it sat back further... so the hole in the cowl hood did not match up with the air cleaner. I cut a crescent shaped piece of metal from the back side of the hole.. and then relocated the piece to the other side of the hole... you can see the three screws holding the piece in place. This worked out good and the hole in the cowl hood now lines up perfectly with the air cleaner.
My grandson spent the weekend with my wife and I. He spent some time out in the garage with me
I have run the engine without the cold air intake for a while... but with the computer control and the IAT sensor the engine runs the best when I use the cold air intake set up and draw the air from outside the engine compartment.
Mario Andretti
Old 08-07-2013, 10:06 AM
chr2002ca's Avatar
Always love your detailed posts and great photos Dave. It seems we're consistently working on the same things on our rides(transmission/clutch -> ride height + wheels rehooped -> cold air setup). I made a similar cold air setup with a 16" aluminum cake pan and realized the diameter needed another inch, so I ordered a 17" cake pan yesterday which should be in a few days. I also was not too happy with the rubber rim ring I installed on my mine and was considering some foam instead. Where did you acquire your foam from? That looks perfect.
Chris Robinson
