Old 01-07-2026, 06:02 AM
HEEP's Avatar
HEEP HEEP is offline
more pictures
Bill
My Build Thread;
https://lateral-g.net/forums/showthread.php4?t=40557
The Following 3 Users Say Thank You to HEEP For This Useful Post:
camcojb (01-07-2026), Goosesdad (01-07-2026), syborg tt (01-07-2026)
  #282
Old 01-07-2026, 06:26 AM
HEEP's Avatar
So after a couple of days with the bumper kicking my butt, I moved into the interior. Getting ready to install the Vintage Air system, the new dash and Dakota Digital gauges, and determine where to mount the ECM, DD module and PSI harness components.
I had seen pictures on Ironworks page of the Chevelles he is building, which are so impressive. Tried to copy the bar that he runs behind the dash to mount some of these components.
I temporarily installed an old Malibu dash that I had, to check fitment.
Bill
My Build Thread;
The Following 2 Users Say Thank You to HEEP For This Useful Post:
camcojb (01-07-2026), syborg tt (01-07-2026)
  #283
Old 01-07-2026, 06:33 AM
HEEP's Avatar
Moving on, I then installed the new SS dash, with the gauges so that I could determine component mounting.
Bill
My Build Thread;
  #284
Old 01-07-2026, 07:05 AM
HEEP's Avatar
Made the ECM mount, then found the mounting spot on the dash bar, tacked it in so that I could check fitment and find the spot for the DD Module. Then removed the dash and set up the DD wiring.
Bill
My Build Thread;
camcojb (01-07-2026), Goosesdad (01-07-2026), syborg tt (01-10-2026)
  #285
Old 01-07-2026, 07:13 AM
HEEP's Avatar
Next was to set up the mounting of the Vintage Air Evap box. I did not want to run bolts through the firewall, as it has already been smoothed. Made some plates with studs welded in so that I could weld those to the inside firewall and mount the unit.
Bill
My Build Thread;
  #286
Old 01-07-2026, 07:33 AM
camcojb camcojb is offline
GREAT progress Bill. Life happens. Congrats on the grandkid.
HEEP (01-07-2026)
  #287
Old 01-07-2026, 10:15 AM
syborg tt's Avatar
Originally Posted by HEEP View Post
Well, it seems I haven't been keeping up with this thread like I should. However, with some life issues like the passing of my father-in-law and the birth of a grandson, some things take precedent.
So I left off with the rear bumper. I started working to try to make it fit better, not necessarily to custom flush and mold the bumper to the body, but to just bring them in t the end, and make them line up with the body a little better.
I’m so sorry to hear about the passing of your father-in-law Congratulations on the birth of a new grandson.
The progress on the car looks fantastic and looking forward to more updates
marty-mj
The Following 3 Users Say Thank You to syborg tt For This Useful Post:
camcojb (01-07-2026), fleet (01-09-2026), HEEP (01-07-2026)
  #288
Old 01-09-2026, 06:04 AM
HEEP's Avatar
So keeping in line with what has been completed. Made a bracket for the American Autowire Hwy 22 fuse block. Got it mounted in the car close to where the original fuse block went through the firewall.
Then moved on to the clutch resorvoir to finalize the mounting and the routing from under the dash of the Malwood clutch system.
Bill
My Build Thread;
camcojb (01-09-2026), syborg tt (01-10-2026)
  #289
Old 01-09-2026, 06:27 AM
HEEP's Avatar
Next up, was making a throttle pedal mount, and getting it mounted in the car. From there, I moved to the PSI ECM wiring going to the firewall plugs. Yes, the wife let me use the kitchen island to lay everything out. She is a jewel, as I am sure everyone's here is as well.
Bill
My Build Thread;
camcojb (01-09-2026), Goosesdad (01-09-2026), syborg tt (01-10-2026)
  #290
Old 01-09-2026, 06:29 AM
HEEP's Avatar
Next comes routing the wiring under the dash. Bought some magnets for band ties that seem to be interesting for the routing. More on that later.
Thanks for looking.
Bill
Bill
My Build Thread;
