Old 03-05-2006, 11:04 AM
Twin_Turbo Twin_Turbo is offline
Thanks for the nice comments..did some more work, new rear crossmember to clear the fuel cell, more bars for the rollcage to stiffemn the kickup area (primary frame weakness of a c2 & c3 vette)..and a shot of the fuell cel frame
Old 03-05-2006, 11:05 AM
Old 03-05-2006, 11:14 AM
Sales@Dutchboys's Avatar
Looks like Quite a project......... But looking good!
dutchboyshotrods.com
269-823-2967
Old 05-31-2006, 05:45 AM
I finished some more stuff, like my front steer end take off rack and pinion setup:
a little movie:
VID
messing about w/ gauge placement:
hard to see but this is a C4 dana 44 in place of the original diff
it has an integrated cooler pump mount (I will mount a pulley on the pinion yoke, this pulley will be a sort of brake rotor at the same time, I'll mount a spot caliper there so I can use it as a parking brake and do away with the junk stock system that never works)
and I'm going to redo the IRS (I had already built a 5 link), swapping to double a arms and custom upright and laying the shocks w/ a pushrod setup
I've already started building it.
Old 05-31-2006, 05:46 AM
Here's my chassis design. You can see the oval piping I'm going to use for exhaust (no mufflers drawn in)
Old 05-31-2006, 06:23 AM
syborg tt's Avatar
looking very nice - love all the fabrication you are doing.
marty-mj
Old 05-31-2006, 06:40 AM
Slick Slick is offline
Nice work on Solidworks also...man I love that program....
Jason Barreca
Audioriginals
www.audioriginals.com
Old 08-05-2006, 02:57 PM
I had finished the 5 bar rear suspension and decided to dump it...instead I decided to do a double a arm suspension so I made a design and got at it. I've got it pretty much finished apart from mounting the shock on the lower arm and welding the upper inner mounts to the frame (after cleaning them up and reshaping them to something decent, they're clamped in for geometry checks)
The design:
The real deal:
Old 08-05-2006, 02:58 PM
I also finished my rollcage w/ a swingout kit
Old 08-05-2006, 02:59 PM
And I completed the front steer end take off rack and pinion....and it even works
Just gotta fabricate an adapter block, much like a bumpsteer block but reversed to bring the tie rod hole towards the rim, since it's a front steer it needs to be outboard of the steering axis for the proper ackerman angle.
