Old 07-08-2008, 07:56 PM
street3285 street3285 is offline
Got the subframe together and ready for the big block. It is a 468 that will eventually get a pro charger, that will be matched up to a 4L80E. We had to use a TH400 trans mount and move it back in the subframe about 4" to fit the 4L80E.
The subframe is under the car, and back on the ground finally! The trans seems to fit in the tunnel with no problem.... only the cooling lines being tight.
Old 03-19-2009, 08:50 AM
Got the mini-tubs mostly installed, just have some finish work to do still. Ok..... quite a bit left. Still have to weld in the g-bar and smooth out the work done to the frame rails.
We welded the brackets for the g-bar directly to the axle, to clean things up and get rid of the u-bolts.
Old 03-19-2009, 09:02 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Great looking project.
Keep the pictures coming!
67 RS/SS
Old 03-23-2009, 10:17 PM
Ordered some Rushforths for the car..... the front does need to be lowered and the side shot has been photoshopped.
You can probably guess the next step is moving forward with the body work, the quarters and tail panel are banged up quite a bit.
Wheels are 20x10 & 19x8 Rushforth Fuels. Smoked Titanium Centers with polished outer.
Travis
Old 03-23-2009, 10:32 PM
GHOSTDANCER GHOSTDANCER is offline
Nice progress
Old 03-24-2009, 03:21 PM
Nice work the car is coming together . It looks sweet with those big meats on the back.
Old 04-11-2009, 12:40 AM
jtnovanut jtnovanut is offline
Default jason
if your smart you wont shave the side moldings most idiots do though
Old 04-11-2009, 01:22 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Should be really nice when complete.
Keep us posted.
Old 04-14-2009, 03:16 PM
The plan is to shave the moldings..... but now that you mention it, it wouldn't look bad with a nice trim down the side. Something to think about.
Travis
Old 04-14-2009, 05:01 PM
G-Body's Avatar
G-Body G-Body is offline
Also may be hot with a factory color on it aswell like the light green they made!
