Old 03-14-2008, 11:46 PM
ls1 nova ls1 nova is offline
Default Best way to finish garage floor
I moved into a house about 6 yrs ago that had a 32x40 detatched garage(just framed) I finished the garage but the floor drains are the highest spot in the garage(there are 3 of them) What can I do to finish concrete floors(that will withstand welding) and hold up to moving heavy objects across the floor plus drain water????
Old 03-15-2008, 07:25 AM
Beegs's Avatar
Beegs Beegs is offline
This subject has been hammered to death over at: garagejournal.com
Check it out and search away!
Bryan
Old 05-15-2008, 11:59 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default floor coating
I did U-Coat It in my new garage hold up pretty good but does show scratches - been over a year now but they told me welding splatter is bad- havent tried that yet , cleans easy and is very slippery when wet!
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
Old 05-15-2008, 02:14 PM
syborg tt's Avatar
Okay here is my advise
I had my floor professionally expoy coated and it's really nice looking. It has one drawback - like very slippery in the winter.
-- which means don't pull in to fast with wet tires ( you'll slide )
So far my wife and both daughters have slipped and fallen on it
but other then that i love it.
marty-mj
Old 05-21-2008, 11:54 AM
Silver69Camaro Silver69Camaro is offline
Yes it is! On any epoxy floor (professional or not), you MUST cover the floor beneath your welding...the splatter and sparks will burn and discolor it.
I went with VCT tile for my garage. It looks great, very durable, cheap, easy to install, and simple to repair. Most big box stores sell the 12x12 tiles for $0.70, add $40 for glue and $10 for a notched trowel. I tiled 650 sq ft for less than $500 and only a weekends time.
The best part is the repair. If you chip an epoxy floor (and the concrete as well), there isn't a whole lot you can do about it. For a VCT floor, the concrete stays intact and you just lay down a new tile. Cheap and easy. Engine stands don't seem to hurt it at all, either. But maintenance is the same: Keep it polished and waxed, keep it clean, keep weld splatter off.
A pro finish epoxy is the ultimate solution, but if you don't want to lay down the big bucks go with VCT. You wont be disappointed.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 08-26-2008, 07:15 PM
Mover's Avatar
Mover Mover is offline
Matt,
That’s a great idea for the garage floor. Can you post pictures?
Craig
69 Camaro RS 327
69 Camaro Custom twin turbo
70 Bonneville 455 Convert "the boat"
Old 08-27-2008, 06:01 AM
bama46fleetline's Avatar
bama46fleetline bama46fleetline is offline
the best thing to do is leave it alone
Old 01-12-2009, 03:17 PM
Originally Posted by Mover View Post
Matt,
Not yet, sorry. I still vouch for the durability of this stuff though, I've been very impressed. I managed to drop a old brake rotor on it a while back, which would have surely chipped the concrete, but it just gouged the tile a bit. Very impressive.
It's also been in the teens for several days last month, no ill effects.
Matt Jones
Mechanical Engineer
