Old 03-17-2008, 02:43 PM
Steve1968LS2's Avatar
Originally Posted by Musclerodz View Post
Steve, did you have any push? Looked like it in a couple shots. I am amazed at how flat the Air Ride cars were going through the course. Thanks for posting.
Mike
Yea, some push. Mostly because my front tires are too narrow (compared to the rears). But the suspension was very compliant and it let the rears force the front through the turn.
My rims will soon be 18x10 and I have some 275s to put on.. maybe 285s.. That should help.
I also need to tweak my spring rates and bar. She will get there, even at this stage Penny is pretty competative. I hope to improve on her over the summer.
Old 03-17-2008, 03:43 PM
brownz brownz is offline
man i had fun watching that video thanks Steve
Old 03-17-2008, 05:26 PM
skatinjay27's Avatar
sweet vid steve!!!!!
it does look like you need to stiffen up the front springs though...it looked good through the corners but it woulnt hurt to be a bit more level.
AJ
Old 03-17-2008, 05:33 PM
it does look likr you need to stiffen up the front spring though...it looked good through the corners but it woulnt hurt to be a bit more level.
I agree.. 450s in there now.. thinking 525.
On Sunday the Air Ride guys upped the comp and rebound which make the car much better. Even with the body leaned over the tires stayed on the pavement, I'm sure most of that reason is the no-bind deal with the three link.
More front tire will help also.
Old 03-17-2008, 05:47 PM
final cut final cut is offline
Steve, great video! Thanks for throwing in a few pics of the Fairlane. I was going to introduce myself , but you were pretty busy , your car looks real good on the track.
Old 03-17-2008, 06:00 PM
lowboy lowboy is offline
Would raising the watts link up one notch help w/body roll? What about a rear swaybar? I have the LD 3-link on my 69 Camaro as well (not running yet) and I'm debating on installing a rear bar. I shot Mark an email awhile ago inquiring about a rear bar for his set up and haven't gotten a response yet. Do you know if there is a rear bar assembly that will work w/3-link?
Thanks..
Old 03-17-2008, 06:11 PM
cmraman's Avatar
cmraman cmraman is offline
Spell check Steve. Shouldn't the title read Goodguys, not GoogGuys?
Old 03-17-2008, 07:00 PM
do you have a adjustable splined type front sway bar? so you could bmake the bar rate harder? cause i seen car perform great with the whole soft spring/big bar set-up.
didnt you go down in spring rate after the accident?
im installing 700# in my car right now... but then again ive got a iron block sbc...
AJ
Old 03-17-2008, 07:12 PM
mazspeed's Avatar
mazspeed mazspeed is offline
Nice cars out there and great job Steve. I wish I could have gone. That is a lame autocross track though. I take it, it was not a N.A.S.A or a S.C.C.A track? More of a weekend proving ground? Still cool to see all those muscle cars on the track. Come up on the 3rd weekend of May to the Duel at DeAnza.
Old 03-17-2008, 07:21 PM
Steve68 Steve68 is offline
So it's becoming true the 18x12 are too big for the rears, smaller rims here I come,
