06-02-2008, 02:08 PM
The LS motors are very nice, but very common. If you want, you can always run injection on the BBC.
I would go with a big-block.
However, I am partial to the sound of big block with a lumpy cam, you can't beat it.
06-02-2008, 03:06 PM
As gas is $4.50 a gallon, Id opt for the LS motors. Plus they add value to your car.
06-02-2008, 04:36 PM
They will all add value. I just would not yank a motor out of a junked late model vette slap it in there and expect to have $100k car. Unless its a blown or turbo charged LSX motor it is just another small block to the masses.
06-02-2008, 04:40 PM
i would do the musi edelbrock big block also much better looking engine than an ls unless you go with a sheetmetal intake. plus the thing get like 20mpg
06-02-2008, 05:00 PM
Lateral-g Moderator
Big blocks are cool. But when you can get 600hp, reliability and 20 mpg, it's hard to think non LS. I've had both. Also listen to Scott's car - sounds awesome (LS7).
06-02-2008, 05:07 PM
co-signed
specially that im running an LS7.
06-04-2008, 07:44 PM
I want to thank everyone for helping me spend my hard earned cash! It figures that 55% of the voters would select the most expensive engine!!!
Based on the comments, a customized LS3 might be the way to go.
I have a sometime, before I am ready for the engine and have to make the final decision. I am currently trying to get the car in paint before my next deployment (Fall 08). When I comeback in the 2009, I will purchase the engine and hopefully finish the build.
Project 69 Camaro: DSE mini tubs, Chassisworks G-Bar and FAB-9 rear suspension, Chassisworks front sub-frame, 14” Wilwood brakes with 6 piston red calipers, 18" Fesler 905 Wheels, Fesler Billet, ISIS multiplier system, Vintage Air, Prodigy Cool Package, Ricks Tank, Turnkey LS3, 4L65e transmission and a lot of other cool stuff!
More pictures: http://camaro69vn10.com The Website is finally Updated!
https://lateral-g.net/forums/showthread.php4?t=13756
06-04-2008, 09:11 PM
Lateral-g Moderator
Having just had a CUSTOMIZED LS motor built a stock LS 7 will be about the same money, just for your info. Good luck.
06-05-2008, 05:04 AM
This is an interesting thread as I'm considering these options as well. I was wondering does anyone think that an LS motor swap will look dated in 10 years? Kind of like an LT motor does now? Its something I'm trying to take into consideration to try to build a timeless car, so it won't look too dated down the road. No offense to anyone, just my opinion... and having said this I'm still leaning toward an LS2/3/$
Ron
69 Camaro Redfire
06-05-2008, 09:58 PM
I went from a carbed 383 to a modified wet sump LS7 in my 69. I couldn't be happier with the swap, but it is expensive and not for the faint of heart. When making the swap to any LS powerplant you have to consider changing the motor mounts, wire harness, some gauges: if not all of them, fuel lines, gas tank, probably the transmission-with controller if auto, exhaust, drive shaft length, an ECU needs to be added.
You can do a carbed LS for less- but that defeats the purpose unless you just want an LS aluminum block. The aftermarket performance stuff for an LS is outstanding and always improving. I went from 335whp with my built 383 to well over 485whp with a NA LS7, and with a little help from Tyler at ATS- well over 500whp. By comparison on the same dyno a new LS7 Z06 with CA intake, LT headers and manual put down 440whp. Some builders are getting more than 700hp from a NA LS7, so the performance is comparable to BB. With that kind of performance, I don't think the LS powerplant will be outdated in the near future.
