Old 07-26-2008, 07:41 AM
scherp69's Avatar
scherp69 scherp69 is offline
Here's a couple pics of mine. Everything bought from Frank.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 07-26-2008, 08:39 AM
WILWAXU WILWAXU is offline
Nice stuff guys! Thanks for the inspiration
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 08-06-2008, 01:27 PM
AJSZR2326 AJSZR2326 is offline
its too bad thats the older g-bar set up wait till one of your upper links bends. didnt see any brakes on the rear yet? what weight springs did you use? i ended up with 200lb ones after the fact. still, it looks good.
Old 08-06-2008, 03:25 PM
Originally Posted by AJSZR2326 View Post
its too bad thats the older g-bar set up wait till one of your upper links bends. .
So you had one bend? Never seen that, and I have seen them in cars cutting some pretty fast short times on slicks!
Frank Serafine
Old 08-15-2008, 06:48 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Frank, Lets talk about this Ricks Tank a little. I have a Narrowed Ricks tank made for exteranal pumps. I have been reading and most people say to go with a internal pump for EFI. Now that being said, Should I send my tank back to rick and have it made for a internal pump or buy a standard tank?
Also my tank does not have the angled side for exhaust. should I have that narrowed or will it be ok as is ?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 08-15-2008, 08:37 PM
Mark, your much better off with a internal pump for packing if nothing else. Also, notches (dog ears) on the corner of the tank help with tailpipe clearance for any 4 link application. It may be best to sell that tank and start over as opposed to getting it reworked. We can keep a note of it when we get a call for that tank, which is pretty often. Also, I might have pre bent tailpipes soon.
Frank Serafine
Old 08-16-2008, 05:49 AM
bigtyme1's Avatar
I agree, will get togethor on this. I spoke with Lisa and she gave me the specs on a new tank. I got a guy who may be interested in the one I got.
69 RS Ragtop
[email protected]
Old 08-16-2008, 05:54 AM
dhutton dhutton is offline
If the tank is a narrowed minitub tank I don't think you need to angle the sides, there is plenty of room for the exhaust. I used one with my G-Bar and there was no problem routing the exhaust.
Don
Old 08-16-2008, 06:21 AM
Don is correct. With a Mini Tub tank you do not need to clip the corners as the entire sides of the tank were trimed down. "MINI TUB" tanks are were named for the original moved inboard leaf spring set ups that were so popular before 4 links came out. Mark's tank is not a mini tub narrowed tank. Marks tank is bacially a full size carb or external pump tank.
When we build a tank for a G Bar or Quadrlink, we do not narrow the entire tank, just dog ear the corners. This helps keep some capacity in the tank.
Frank Serafine
Old 08-16-2008, 06:33 AM
bigtyme1's Avatar
Correction, it is a narrowed minitub tank but with external NTP connections for external pump.
69 RS Ragtop
[email protected]
