Old 09-15-2008, 12:24 PM
camcojb camcojb is offline
well, I found the reason I'm having a problem with the boost levels. The intercooler was not built for this power level, and simply won't support my airflow needs.
I have a 24" wide by 12" tall and 3" thick core with side tanks. So the unit has air flowing horizontally, which is very restrictive with that config of a core. If I could swap to a vertical unit, the same size core would be much more efficient as it'd be 24" wide and only 12" long. Unfortunately that won't fit without a complete re-doing of the front end of the car. According to Bell my intercooler config and size is only real efficient up to 400 hp or so.............
The tech at Bell guessed the exact boost drop of my combo just off the intercooler specs and boost level into the core; I didn't have to tell him. My plan is to bypass the intercooler for now and plumb the turbos directly into the throttle body and run water injection as I have in the past. It may not be ideal but it definitely works and I'm sure the power difference will be huge.
Thanks for all the help, it is much appreciated.
Old 09-15-2008, 12:49 PM
deuce_454's Avatar
or you could mount two water/air intercoolers in each fender in front of the tire! or re-map the EFI and run E85 and full boost, sans IC... mut the water/meth injection is propably the best and quickest fix
Jake: Hit it.
Old 09-15-2008, 02:01 PM
I think the easy thing to do for now is bypass the intercooler, build new custom pipes up to the throttle body, and keep the present intercooler in place in case I sell the car in the future and the guy can live with the lower boost.
I'd go E85 if it was readily available out here, but it's not. There's one place supposed to be opening up this month, but I want to do Power Tour and longer cruises, so unless they get a good network of E85 stations out here I have to stick with pump gas.
Old 09-15-2008, 02:23 PM
Tom.A's Avatar
Tom.A Tom.A is offline
Jody,
Sorry kinda off topic but I was wondering what kinda of HP does it have a 12 psi (or current state) and what would you expect at 18 psi? No other reason than curiosty...I am guessing it is BIG POWER
Tom
Old 09-15-2008, 02:48 PM
Originally Posted by tom_a View Post
Jody,
12 psi feels like 700-750 hp. 17-18 psi should be 1000+ hp.
Old 09-15-2008, 02:52 PM
Tom.A's Avatar
Thanks, it was strictly for my purposes.
Tom
Old 09-15-2008, 03:47 PM
Blown353 Blown353 is offline
12 psi feels like not enough hp. 17-18 psi should be 1000+ hp.
There, fixed it for you.
1969 Chevelle
Old 09-15-2008, 04:19 PM
that's actually sad but true Troy. It's stupid that 700 hp feels pedestrian.................
Old 09-15-2008, 05:17 PM
awr68's Avatar
awr68 awr68 is offline
Well at least you got to the bottom of it! So there's no way of fitting a proper size IC or two?
Tony
'68 Camaro
Old 09-15-2008, 05:55 PM
sure I can, but it'll require a fair amount of fabbing and some re-pinting of the front inner sheetmetal. Would be a cool winter project I guess, but for now I want to get the boost up and enjoy the car.
