View Poll Results: Should we blow it or gas it?
Screw the extra weight, you have to ProCharge it! 18 64.29%
Save the weight a spray the crap out of it! 10 35.71%
Voters: 28. You may not vote on this poll
Old 09-12-2005, 06:33 AM
Payton King's Avatar
Default spray
I think it was last year that a blue Z06 won the One lap of America race. the car had a 427 LS1 with spray. I believe it(spray) was used on the drag portions, top end runs and maybe long staights on the road coarse.
To your question...NA with spray and a progressive controller. I am thinking 700 is going to be plenty for all of the above reasons and you car is going to have the "Wow" factor from the way you are building it.
Old 09-12-2005, 11:19 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Originally Posted by ProdigyCustoms
Realistically, 700HP would be PLENTY, but in a world full of 1000HP cars, it needs to have it.
Frank-
Since asked for an opinion.. You said in a world of 1000 hp cars, it needs to have it. Well, your car is so out of the ordinary & ahead in so many other areas I wouldn't worry about it, besides when will you ever be able to use it all? The car will handle so much better w/out the extra weight up front, not to mention how much cleaner it will look. Not sure what kind of intake you are using, but a fabbed Sheet Metal Intake would look killer. But then again I'm kinda partial to them. Either way..The car is amazing & can't wait to see at SEMA.
Brent
Old 09-12-2005, 04:04 PM
Done deal. it will be a All Aluminum 540, N/A motor. Should be 750HP no problem, maybe more depending on how nice the heads come out. Still trying to work out the nitrous, but even without, it will be awesome.
Thanks for the opinions and compliments. Let's see if it can live up to the hype.
Old 09-12-2005, 06:45 PM
Canadian_Hot_Rodder Canadian_Hot_Rodder is offline
Sounds awesome to me. You won't be sorry with that choice. Throw on some AFR 335 CNC'd heads and AWAY you go!! Those should be able to feed that sucker.
