Old 08-18-2009, 04:42 PM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
I bought a used Peterson fuel filter cut off the -16 AN end fittings, welded in aluminum plugs and drilled and tapped it for -6 AN / 3/8 npt fittings. Used filters with large AN fittings normally sell for very reasonable prices. The outlet line runs to a bulkhead fitting in the trunk floor with a small S & B filter attached to the bulkheads other end. ( the filter is located just behind the driver side rear wheel well. )
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 02-17-2010, 08:19 AM
Bow Tie 67's Avatar
ooops
Matt
Old 02-17-2010, 08:33 AM
Bow Tie 67's Avatar
Default Racing Season #3 prep / mods
Last year several issues poped up.
1. The clutch had intermittant problems. Solution: I'm installing a 7/8" bore Tilton master cylinder and an adjustable clutch pedal stop.
2. With the R compound tires I would get oil pressure fluctuation in long corners. Solution: Accusump accumulator and oil cooler install. I used some angle iron I had laying around, so she looks like a piece of farm equipment. LOL some time in the future I'll make something nicer, but for now function over form.
If you look close at the brackets I welded to the sub-frame you can see I incorporated tie-down / tow-hooks.
3. My front street tires, sucked!! ( major push on an auto-x ) Solution: I sent out the front rims and had them widened to 10" and mounted 275 BFG KDW's.
Matt
Old 02-17-2010, 08:56 AM
Nice additions. That's a good place to put the accusump. Not many options.
Old 02-17-2010, 09:41 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Awesome.
Thanks for the update.
Old 02-17-2010, 05:33 PM
I agree nice work.
