Old 03-25-2009, 08:52 PM
buickfunnycar.com's Avatar
Thumbs up
Sounded awesome for that short burst,made my #'s look wimpy by comparison...but my little 383 sounded like a freight train all the way up to 6800rpms.
You got a good 100 lb ft of torque on me (391 rwtq),would love to hear what your 1/4 mile times are...congrats,awesome looking car,especially in Black!
Gotta love big blocks...
www.buickfunnycar.com
Old 03-25-2009, 10:10 PM
Originally Posted by ProdigyCustoms View Post
The 100 octane thing is a myth. if the car does not need it it will run faster on lower octane.
The reason there are different race octanes is you only want to run the lowest you can get away with. My street racer is a pump gas motor and looses a full 1/10th on 110 octane on motor. But needs the 110 to be safe on nitrous.
So long story short, at 9:1 compression, 100 octane would steal power.
500HP at the tires at 3500LBS is plenty to run high 10s. One trip to the dragstrip and I bet I am sending him double adjustable shocks and Prodigy Bar ends!
I agree that to much octane will actually rob power. We were just talking about a mix to say 95-97 octane where I could go to 44 degrees total and not worry about detonation to try and get that 500/500. Going from 39 to 41 gained me 8 ftlbs and a 2 horse. Every time I added timing I gained. He had mentioned he has seen many big blocks love 44 degrees due to the large head chamber. If I was to try for the 500/500 I would mix 50/50 91/100 unleaded, change the pre load on the lifters to one full turn for better performance over 6k, and try 42 then 44 degrees of timing. I won't dyno it again unless I make a major change. To big a hastle getting it on that rack.
Old 03-25-2009, 11:19 PM
skatinjay27's Avatar
not out here in vegas... with good 60fts it should run mid-to low 11s, with a GREAT 60ft i could see a high 10 though.
yea the car has some serios traction problems.lol
when todd just lighty accelarates to pass a car its starts getting sideways lol
yes it needs stickier tires but i also feel it need some suspension tweaking...
AJ
Old 03-26-2009, 12:23 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Payback+Traction?
Curtis
Old 03-26-2009, 03:40 AM
GvEman's Avatar
GvEman GvEman is offline
Wow nice vid! and nice numbers!
1998 CamaroZ28
Old 03-26-2009, 08:25 AM
Payback+Traction?
Easy now...with the lack of rain the city streets get really greasy. I can hook it in second gear full throttle on some clean pavement. Pulls really hard. 1st gear is a challenge to say the least
Old 03-26-2009, 10:54 AM
Spiffav8's Avatar
Lateral-g Moderator
Just saying it's going to be a challenge is all. When you get that beast to hook it's going to be like a catapult shot off an aircraft carrier!
Curtis
Old 03-26-2009, 12:43 PM
monza's Avatar
monza monza is offline
Nice numbers and great sound for sure! You might like this, you already might be past the 500hp with those readings. My dyno guy stated when we were running on that dyno that, " the humidity in the brick was off" and it could easily be out by 10-20 hp in your favor.(I guess it's a common problem on that particular dyno) I have no idea what that really means except your numbers are actually higher! Garth (from Leading Edge) did not really want to acknowledge that and the subject was dropped quickly.
No doubt... how many times did the wooden ramps go shooting along the floor for you. ha ha? Full blown clutch/leg work out!
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 03-26-2009, 12:48 PM
He actually said his dyno was really tight and most guys complained of low numbers. I noticed the sheet says 5% humidity but the weather said 15% yesterday. I'm sure that would effect the correction factor. Oh man my foot was tired after getting it on that rack. I ended up bending a v clamp as well. Glad to hear it may be conservative. What did you end up making on his dyno?
Old 03-26-2009, 01:01 PM
Flash68's Avatar
Flash68 Flash68 is offline
If I recall correctly, Scott ran his 69 with ~500 rwhp and 335 drag radials to the tune of 11.50s. Even though one is a big block and one is LS7, pretty darn similar cars. That's where my prediction still stands.
High 10s? Yeah, if he throws on 15" big n littles, drag shocks, and a wicked clutch dump!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
