Old 04-04-2009, 12:58 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Originally Posted by ProdigyCustoms View Post
ItDoRun, I was just up there droping a project and picking up 2 more projects. I have 2 projects to deliver in a few weeks, one to Dothan, Ala and New Orleans, then swing up to Vicksburg to grab a couple more projects for the shop. I might have to swing by and check up on you! How close to Biloxi are you? I will have to stop by there on the way home.
Frank,
I'm actually about an hour and a half west of New Orleans (in Baton Rouge), but it's all interstate and a pretty easy drive. If you've got some time to kill, let me know. You're more than happy to swing by. I need to talk about front suspension with you anyway. Plus, it would definitely be nice to meet you in person and put a face with a name.
Chris
Chris
Old 04-04-2009, 08:06 PM
Weldon0405's Avatar
Weldon0405 Weldon0405 is offline
Originally Posted by ItDoRun View Post
I'll be installing mine soon. Come by and see it first hand if you're in the area.
I'll probably get to the BR area for a weekend within the next month. I'll let you know when I'll be in town.
WELDON MALBROUGH
SSG, USA
Fort Bragg, NC
It is great to be back in the States!
Old 04-05-2009, 10:40 AM
syborg tt's Avatar
No suspension system that uses stock rear frame rails is going to ride that low without being on the stops. EmptyNest is probably one of the lowest stock frame rail ride height cars around, and even with extended rockers is over 6" rocker to ground measurement.
So it is not a given suspension that limits ride height. This kit has enough adjustment to ride on the stops, but you would not want to do that
Thanks Frank - looks like i'm going to be cutting the next one up a little more then i planned.
marty-mj
Old 04-10-2009, 04:35 AM
ibdmann ibdmann is offline
for a 69 camaro thats mini tubbed it's written that you need the weld on brackets with off-set bushings to bring the lower bar in-board. Are the brackets welded inboard of where the original leaf spring perch's were located on a 69 camaro. Anything you can add would be appreciated
thanks
Old 04-10-2009, 07:07 AM
Because the lower link bar is so fat. If you are doing a mini tub car you have to use the weld on brackets and offset bushings specified in your kit order. We did th weld on brackets on Louis car. These brackets eliminate the leaf spring perches and moves the bars in for tire clearance.
Frank Serafine
Old 04-10-2009, 02:26 PM
crazycarl's Avatar
crazycarl crazycarl is offline
That's sweet.
I'm probably just screwing with you, so please don't take it personal.
Old 04-14-2009, 11:57 PM
ViperBlue68's Avatar
ViperBlue68 ViperBlue68 is offline
Location: Yuba City, CA (about 1/2 hour North of Sacramento)
Thumbs up
looks realy good! what size wheel and tire is on the back?
J.T.
Old 04-15-2009, 06:02 AM
Those are 335 / 30 / 18s.
Frank Serafine
Old 04-16-2009, 01:53 PM
ItDoRun's Avatar
Those 335's are tight under there!
Chris
Old 04-16-2009, 02:04 PM
Plenty of room. Were dialed in on all the measurments. Remeber we have 335s under MotiV8tr also
Frank Serafine
