Old 08-21-2009, 08:45 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
I think I'm going to do some homework on my options and try to compare cost/benefits.
Scott from NJ
Old 08-22-2009, 08:10 PM
R67Chevelle R67Chevelle is offline
I am interested in using this on my 71 Ford F250. The 390 is going to be rebuilt next month. It will have about 370hp with 460ft lbs. My problem is that the truck has duel fuel tanks and there is no way I know of to due a fuel return. Can anybody answer this for me?
Blessings,
AMS
Old 08-22-2009, 08:38 PM
Steve1968LS2's Avatar
Blessings,
AMS
Well, the system doesn't HAVE to return to the tank it's drawing from, but it can't return to a full tank.
Maybe a valve to move the return when you move the feed. Just don't forget.
Or cross the two tanks together if they are close enough to prevent one from becoming "over full".
In any event I don't see it as being a difficult problem to solve.
Old 08-24-2009, 04:20 PM
g356gear's Avatar
g356gear g356gear is offline
I guess my biggest question is how the stock fuel system is modified to work with this system and if you need to run a return line to the tank.
"FAST™ engineers set out to develop the ultimate fueling strategy for the EZEFI ™. The EZ-EFI™ features patent pending technology with the most advanced self tuning control strategy available anywhere today. Simply hook up the four necessary wires and any optional wires, answer the basic setup Wizard questions on the included hand-held display and the system tunes itself as you drive. Countless research and development hours were spent on a number of prototype test vehicles to develop a high-quality system truly worthy of the FAST™ brand.
Capable of supporting up to 550 horsepower engines, the FAST™ EZ-EFI™ Self Tuning Fuel Injection System can be purchased as a complete system, including the ECU, wide-band oxygen sensor, wiring harness, fuel injectors, optional fuel pump kit and other assorted components, including the innovative 4150 Throttle Body from FAST™.
The FAST™ 4150 Throttle Body delivers the total package approach for anyone with an existing 4150-type intake manifold. Everything comes with the kit, including appropriate fuel injectors and fuel rails. In addition, it works with the original carb-style throttle linkage & is ready to accept all OEM sensors.
Old 08-24-2009, 04:25 PM
You need a different bypass regulator, fuel pump, for starters.
Old 08-24-2009, 04:28 PM
camcojb camcojb is offline
you will need a return line to the tank. I deally you need baffling added to the tank, or run a separate surge tank or custom efi tank to control fuel slosh picking up air in the system. But technically the stock tank will work with an outlet and a return line, but you'll want to keep the tank close to full level-wise so it doesn't suck air which is an immediate studder or engine shut off with efi.
Old 08-24-2009, 08:42 PM
I'd do the DUAL fuel tanks with a crossover line (or two - One top and one bottom) like my boat fuel tanks are done. Be sure to add shut off valves! With crossover lines open - both tanks will seek their level so always having fuel in the one you'd be drawing from.
Barring that "fix" -- you could use a "Y" feed from both tanks - and a return "Y" to both tanks.... but I think I'd prefer a single feed and single return with the X over for simplicity.
Old 08-29-2009, 07:46 AM
69496 69496 is offline
Posting here to try and keep this thread going. I am very interested in this system but my HP is slightly above the range listed by them. I saw somewhere in this thread that the HP could possibly go up, then again Penny posted that it will be limited because of the fact it has fewer injectors which obviously makes since. Just hoping FAST will be able to squeeze a little more out of it and then see somebody try it before me. Any guinea pigs out their
Old 08-29-2009, 08:49 AM
It's just a matter of math.. when you only have four injectors to work with you can only support so much power, even with massive injector sizes.
I think FAST just told me it can go to 650 hp.. I will confirm.
We are dyno testing it on Tuesday.
Old 08-29-2009, 03:00 PM
edit....
