Old 06-08-2009, 08:18 AM
ArisESQ ArisESQ is offline
Originally Posted by Steve1968LS2 View Post
I do believe it does..
i could be wrong, but off chris alston's site, this is the description for the clip;
http://www.cachassisworks.com/iwwidb...MARO1?COMP=CAC
7701
67-72 CAMARO/FIREBIRD/NOVA BILLET MOUNTS
Price $ 1789.00
Direct bolt-on-clip for '67-69 Camaro, Firebird, and '68-72 Nova. The frame is factory welded in our special fixture. It is laser cut, formed and welded out of 7 gauge steel. Front clip keeps the tire in the stock location, there is ample room for up to a 17"x8" front wheel with 4-3/4" back space and P225/45-17" tires. You will reuse the factory radiator core support and bolt it into the front clip. Your front bumper, radiator, and grille will bolt back in the original location with the weld-nuts fabricated into the frame. We manufacture the billet rack-&-pinion to match the suspension crossmember width. When you add the Street Machine front suspension package to the clip, this assures you will have perfect suspension geometry (unlike our competitors who only have "Mustang II" suspension crossmembers and tell you they will fit the Camaro, Firebird, and Nova). The engine is mounted in the stock location, with billet side mounts or motor plate and mid plates. The package includes welded frame with all suspension mounting points; mid-plate brackets; emergency brake cable mounts; hardware and fasteners; and 104-page photo-illustrated instruction guide. Billet motor mounts or motor plates; and bolt-in mid-plates; urethane or aluminum body bushing; clutch pivot shaft bracket; rubber inner fender splash guards, and bolt-in subframe connectors are optionally available. Shipped in a palletized box, by truck, freight collect.
have they released a newer clip??
