Old 07-30-2009, 03:36 PM
brian mc's Avatar
brian mc brian mc is offline
Default Wd-40
I heard something similar about WD-40 that it turns into a poisonis gas when exposed to high heat like welding or torching, i didn't research it, just heard it from an old-timer who worked in a shipyard....
Old 07-30-2009, 07:18 PM
Patrick's Avatar
Patrick Patrick is offline
Wow....that is F'ing scary. I use brake clean all the time. Thank you for posting this article.
1968 Camaro--LS1, Kenne Bell Twin Screw
http://www.cardomain.com/ride/2486483
Old 07-30-2009, 07:27 PM
awr68's Avatar
awr68 awr68 is offline
Greg did you find out anything today at AirGas? Do they know of any cleaner that is safe to use?
Tony
'68 Camaro
Old 07-31-2009, 04:07 PM
rwhite692's Avatar
Thanks for posting that!
Wasn't Phosgene used at one time as a chemical weapon?
Oh wait, here we go:
http://en.wikipedia.org/wiki/Phosgene
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 08-01-2009, 06:58 AM
BlkBird's Avatar
BlkBird BlkBird is offline
Wow....and as fast as brake cleaner evaporates you would think the heat would've made it "go away" well before he got close enough to really hit it....you never know what's gonna get you, do you?!
Mike
1971 Pontiac Firebird Esprit
www.hereticmetal.com
Old 08-01-2009, 08:11 PM
RaceMan's Avatar
RaceMan RaceMan is offline
Wow !!! Good info Thanks !!!!!!
SPEED IS ALL YOU NEED !!!
Old 08-02-2009, 06:36 PM
jst8a5.0's Avatar
jst8a5.0 jst8a5.0 is offline
Yeah that's scary! I used brake cleaner because I thought it would be effective. There was one particular incident about a year ago where no matter what I did with the settings and how I cleaned the aluminum, it would not weld without getting nasty. I finally called up Thermal Dynamics and he immediately asked what I used to clean it. I said brake cleaner and he cut me off and said, "Did you smell sour apples?" I told him yeah and he told me that smell is a toxic gas and can kill me with a few wiffs. He told me the only chemical to clean aluminum that was "safe" was acetone.
Micah Prudhomme
Concept Fabrication, LLC
Shop page:
http://www.facebook.com/ConceptFab2006
Shop channel: https://www.youtube.com/my_videos
Old 08-02-2009, 06:45 PM
Okay... but now I'm curious as to what was the cause of the bad welding?? Is that related to using Brake Cleaner as well??
Seriously -- I'm going to AirGas on Monday to see what they recommend as a cleaner - because after learning of the Phosgene gas thing - I really don't want to inhale any "burning chemicals" --- I quit doing that back in high school!
Old 08-02-2009, 07:48 PM
jst8a5.0's Avatar
Me too!! LOL!! As I think back, maybe some clear coat had settled on that particular piece because I cleaned, wire brushed, pre heated, set the welder to max clean to bury the impurities (not a common practice at my shop). Yeah I felt like I was asking directions because I was admittedly lost. LOL! When you weld anything, material and filler rod need to be clean to get great results. Aluminum is particularly picky about being clean before welding. Just don't use brake cleaner. If you do multiple tasks in your shop or work space like I do, keep your metal covered and your filler wire out of the elements however you can.
Micah Prudhomme
Shop page:
Old 08-02-2009, 08:14 PM
I keep all my TIG filler in gasketed tubes... CLEAN and DRY and dust free... I just label the outside with a sharpie...
I even scuff the edge etc on aluminum - even with the 'cleaning action' (I have a Miller Dynasty 200 DX)... I guess maybe I'm old skool...
