Old 01-05-2010, 07:11 AM
TravisB TravisB is offline
Originally Posted by RPM HOTRODS View Post
The front is based off a Mustang II, Heidts made the front, The control arms are about 8.25" from the center of the ball joint to the center of the rod-end with adjustments both ways, 4 link rear, Speedway style front and rear swaybars Rocker height is about 3.75 behind the front wheel and about 4 in front of the rear tire. The quarter glass took a little work. But we got them to work perfect. We notched the tubs just a pinch and reworked the tracks slightly and it all worked out. It was nice to work that out while the tubs could still be removed. But the opening remain in the stock location. Travis do you still have the dually?
No I traded it awhile back. Im building a 62 nova now....
Kenny Davis Hot Rods
Old 01-05-2010, 08:33 AM
Kendall Burleson Kendall Burleson is offline
kILLER JOB AGAIN MORE PICS. lOVE THE STANCE
Old 01-05-2010, 02:58 PM
Heidts#14 Heidts#14 is offline
BUZZZZ!!!!! WRONG. Please do not affiliate this subframe with mustang II geometry . It is a modified version of our Camaro Pro-G subframe .
Old 01-05-2010, 04:50 PM
camcojb camcojb is offline
yeah, if you want to get Chassisworks wound up say the same thing about their g machine front clip...........................
Old 01-05-2010, 05:45 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Come on Curt, WTF, you are better than that! I wouldn't sell you a Mustang II.
This is our latest Nova Chassis. The front uses a modified Heidt's Pro-G. The rear is our 4-bar set up with a 9".
www.roadstershop.com
Old 01-05-2010, 07:31 PM
wiedemab's Avatar
wiedemab wiedemab is offline
That's an interesting frame setup - in a good way. When I looked at your site I didn't realize that the picture you show for the Chevy II frame is one of your Chevelle Frames (right?). I just glanced at it and saw that it used C5/6 spindles/uprights and assumed that would be the case on the Nova frame. Not that there is anything wrong with any other setup, just an observation and assumption that I made that was incorrect.
Very cool build - I'll be following this one!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 01-05-2010, 07:51 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
This may be a little off-topic, but what do you guys do with the VIN plate on the firewall? I see a few Novas being done but the VIN plate never gets put back on the firewall. What happens when it gets registered?
Old 01-05-2010, 08:04 PM
Glad you chimed in.... how about some specs on the front...?
Camber gain per inch?
Caster?
Instant center
Scrub?
RC?
Old 01-05-2010, 08:49 PM
RPM HOTRODS's Avatar
RPM HOTRODS RPM HOTRODS is offline
Boy..... I didn't realize I could get in so much trouble on here. One mistake and everyone is on my butt!!!! And the bad thing is that I knew what it was. That is what happens with 14 employee, 10 projects, 3 kids and twins on the way. I finally think I may be loosing my mind. We do have some mustang II spindles on Ebay. I guess I could always say the damn chassis builders didn't give me a clue on what I got from them!!! SORRY it will not happen again.
Old 01-05-2010, 08:56 PM
Few with the wheel off.
