Old 01-31-2010, 09:04 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Is it leaking at the oring or flare connection?
Can't tell yet, I think it's from the o Ring side.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 01-31-2010, 09:11 PM
bigtyme1's Avatar
Tride to pull the AN fitting off and it broke off in the trans. Wanna buy a car cheap!!!!
69 RS Ragtop
[email protected]
In that case, I'd remove the fittings and make sure the sealing surfaces are flat and clean.
Old 01-31-2010, 09:47 PM
bigtyme1's Avatar
I was able to get it out with a easy out. Lucky!!! there is no o rings, this is a 45 swivel ans it uses a brass bushing. what did I do wrong? I'll get new fittings tomorrow
69 RS Ragtop
[email protected]
Old 01-31-2010, 09:53 PM
Your fitting doesn't line up with you threads??? The copper sealing washer is not be compressed on either side. Is you fitting tweaked?
Old 01-31-2010, 10:11 PM
bigtyme1's Avatar
I got to go to bed, but I'm glad I got it out ok. I'll call you tomorrow if your not busy. I need to get new fittings anyway. Any suggestions?
69 RS Ragtop
[email protected]
Old 02-11-2010, 07:47 PM
79 Camaro 79 Camaro is offline
Check with the guys Godman fittings. I've used the on my 4L60E/LS1 swaps. Used a liittle teflon sealent paste on the threads just to be sure. Zero problems. Also used Lokar trans dipsticks with zero leaks.
Old 02-17-2010, 10:59 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
Originally Posted by HRBS View Post
Mark... how long was this trans sitting before you put it in the car and ran it ?
Could be that the front pump seal dried out during storage or may not have been replaced on the rebuild. If its leaking from there it would weep out of the inspection cover and coat the pan with fluid making it look as if it was coming from say the dip stick inlet.
Throw that bad boy on the lift and have someone start it while you look from underneath. That way you're not guessing.
Now, that's thinking with your dipstick Jimmy
TJ Ragucci
http://www.northeastrodrun.com/
