Old 02-20-2010, 06:31 AM
Originally Posted by RECOVERY ROOM View Post
I cant type worth a damn.Takes to long,I'm getting better
Every one is right about the expectations,The more work you have done the more it cost.Most of the time a pro built car will cost more.
Tracy -- I was referring to TODD... but talking to you!
Old 02-20-2010, 07:24 AM
Originally Posted by maxspeed View Post
Thanks for the answers
Another thing i was wondering, i dont see many finished pt cars for sale people dont sell them or i am searching in the wrong places ???
Go to the "for sale" section here in the forums --- you just missed 3 or 4 cars that were REAL REAL nice cars - DONE - for way under 100 grand... and had all the right stuff.
With the economy the way it has been - there have been some fire sales... so if you are looking for a done project - check the for sale sections here and over at Pro-touring.com.
As you can see - there's just no way to tell you what something like this will cost - without a full description of exactly what parts you're wanting to use.. what your base car is - and it's condition. (I just checked in... to see what condition my condition is in.... ).
I worked for a year and a half with a buddy that had NO LIMIT... he just knew exactly what the end result was to be. He did NOT want a car that had to have any bodywork or paint... but EVERYTHING ELSE was to be replaced. So a new Art Morrison frame w/Ford 9" - LS2 motor - Tremec 6 speed - Wilwood brakes - Budnik wheels - full new interior (stock appearing) - all new wiring - power windows - power door locks - new steering column and wheel - new stereo and speakers - Vintage Air - Billet specialties Tru Trac serpentine belt - new SS fuel tank w/internal pump - SS brake and fuel lines - new crossflow radiator and core support - new HID headlights - new driveline - new fiberglass inner wheel wells - SS exhaust "kit" - STOCK headers slicked and porcelianized - new windshield wiper system - every square inch of interior covered with Dynamat - including trunk - new factory appearing gauges . Cost of base 55 chevy 2 door post car - $25K - fuel to fetch it - 1 grand - total parts INCLUDING the cost of the base car and fuel - $99,700
NOW FOR LABOR (in this case FREE)
Body was removed from stock frame and mounted on my rotisserie - gutted - floor and trunk pan mods - new tunnel for tranny - firewall slicked and painted - Chassis lines and electrical run and SS exhaust with trick hangers built - blown apart and powder coated then reassembled. Modify rear floors (raised) - modify trunk pan - built mount for E brake handle - Body undercarriage scraped and cleaned - painted with POR 15 - and undercoated - Body required ZERO repair or paint except the firewall and inner fender wells - cover in Dyanmat - install motor and trans in chassis - drop body - install core support - mount reservoirs - scribe and cut inner fender wells - remove for paint - re-install - complete new wiring - dye headliner - rebuild door hinges - drill for door looms - rebuild windows (rear) - install new power windows - rebuild wing window regulators - install power door locks - install all dash items and trim - install custom hoses for A/C and heat - build custom closeout for trans shifter - build custom mount for DBW throttle - rebuild clutch and brake pedals - custom fabricate hydraulic clutch reservoir mount - modify steering column mount in firewall.... and a whole host of little things which I can't even remember now... my point -- MOST of these mods done with the body in white (ie not finished) required many assemble/disassemble/reassemble check for fit/modify/reassemble with proper hardware (polished SS)..... So the amount of LABOR in a build like this is double or triple the amount of time that would be used to just "R&R" a stock part. AND THIS IS NOT A FANCY BUILD!! It's a very nice modified STREET hot rod. I have EASILY 1000 hours in this build with all the cleaning - and assembly / reassembly. Wiring alone took two people two full days (long days) to finish. Here's the deal on that - It's a 1955 --- with everything new - we get to the bulbs in the turn signal/parking lamps... and I end up rebuilding them with new receptacles.... no way you're going to do all this and leave stupid little stuff like that go "untouched"... but it takes LABOR.... and more little "un budgeted" parts and time to find and fetch said parts....
So - If I was keeping track of all our labor - and charging for it @ $45 an hour - you'd add $45 GRAND to the parts bill - and we'd be at $145,000 "so far" ---- and that is with NO PAINT OR BODYWORK....
Thus my "$150,000" real money - real life - guesstimate. You'd have a real nice - nothing fancy - very squared away car - that wouldn't win ANY trophies... but you could drive without fear and enjoy the heck out of it.
FIRST PIC -- AS bought -- second pic -- "near" being done...
Old 02-20-2010, 07:39 AM
Steve1968LS2's Avatar
I keep thoughts of how much I've spend out of my cranium.. no good can come of it.
Old 02-20-2010, 07:49 AM
HRBS's Avatar
HRBS HRBS is offline
Greg... you got some set of balls hangin wheel dollies up like that. I hope your wife or kids dont come home and hit the garage door opener on their way in....
In regards to the thread... I always tell people for a "decent build", "you're $50k in parts alone before a wrench is even touched". From there, we can build a "bolt together car" or fabricate our own design (which is simply time x hourly rate).
HRBS on Facebook
Old 02-20-2010, 07:50 AM
Steve -- Truer words have never been spoken!
Italian bookeeping (3 Sets of books):
#1 - Actual costs
#2 - What you tell the wife
#3 - What you report to the government
Old 02-20-2010, 07:51 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Did they repeal don't ask don't tell yet? That is how it works here, my wife does not ask and I do not tell.
Scott from NJ
Old 02-20-2010, 07:53 AM
My wife is the one that put them there!
She had them over my office chair before I asked her to move them.
Seriously --- they're on SS CABLE... over 8' high - and nowhere near the door or anything that can hit them or that they interfere with. Pictures never show the "actual" depth etc. I wasn't born yesterday - or the day before either.
Old 02-20-2010, 07:56 AM
Count the panels on the door - that first door is a 10' er -- the second is a 12'...
Old 02-20-2010, 07:57 AM
HRBS's Avatar
Relax. I was being sarcastic.
HRBS on Facebook
Old 02-20-2010, 08:43 AM
realcoray realcoray is offline
hi folks i am from norway and been here at lateral-g forum for a while just watching all the amazing projects and builds. So many people with amazing skills here.
What i was wondering is what is the cost of a build of a pro touring car ??
I know it is a stupid question becouse of the difference in the builds, but if you start with a good clean car and want a nice finished pt car that you can use, dont have to be any show queen.?
And i am thinking of if you let some proffesionales do it for you, becouse i dont have the skills it take to build a car like that..
any ideas ???
If you have professionals do it for you, 75k+ and it would go up quickly. If you do it, you can certainly build a very solid car for 30k or less. It won't have the fanciest wheels or a shiny new engine but could it look great and perform as good as the cars that do? Yes.
