Old 04-05-2010, 08:51 PM
Grnova's Avatar
Grnova Grnova is offline
Hey Greg I will consider myself a NEWB when it comes to brakes. Do you think you could give me you opinion on my situation. http://www.pro-touring.com/forum/showthread.php?t=67069
Old 04-05-2010, 10:12 PM
GR ---
Yep I can help you a lot! Call TOBIN at KORE3
http://www.kore3.com/
Don't take "advice" from a bunch of DB's on a forum... talk to a real expert about what you have and what you are going to need to "fix" it.
My initial advice is that you're running a "hot rod" brake (I have larger calipers and rotors than that on my 37 Ford!) on a car you're trying to "track" --- but even then --- you should be able to lock the brakes up on the street. Period. If you can't then you have something out of whack - which you already seem to know.
Old 04-05-2010, 11:27 PM
nullshine nullshine is offline
Removed.
Old 04-06-2010, 08:53 PM
Grnova's Avatar
GR ---
I did talk to t Wilwood tech guy and he said that I need the 3 factors for good brakes:
1) Good brake pressure 900 to 1000
2) Pedal ratio 6:1
3) friction- which I did not have until today when I installed my new pads...BP20's
The car finally works like I wanted it to These pads are considered a mild race pad but since I am not running drilled or slotted rotors they should last me some time...How long ? don't know yet.
But that is one more thing I can cross off the list.
Old 04-06-2010, 08:59 PM
And there ya have it!
Good!
Now -- BED THEM IN...
Then let us know if you can lock up all four wheels...
If you can't... you've still got some work to do.
