View Poll Results: Which rearend should I buy
12 bolt w/ 33 splines 61 62.89%
9in 36 37.11%
Voters: 97. You may not vote on this poll
Old 04-17-2010, 03:23 PM
I only got Frank by 32 seconds in his 2010 SS on the road course at RTTC. (I've took shorter naps)I'm sure that 9 inch parasitic drain will only take him back to 33 seconds or so. I can't wait for this response!
I was writing a order will driving.
Frank Serafine
Old 04-17-2010, 03:43 PM
That wouldn't surprise me.
Old 04-17-2010, 07:12 PM
Originally Posted by BMR Tech View Post
An aluminum centered 9" is lighter overall, allows much easier gear and posi swaps, and doesn't rely on C-clips to retain the axles. The ring gear is slightly larger, pinion bearings are larger, and you just have more options for internals. I am a die hard Chevy fan but I would use a 9" over a 12 bolt everytime if I was starting without anything...
Yes exactly the reasons I voted 9 inch over 12 bolt
Old 04-25-2010, 03:07 PM
lil427z's Avatar
lil427z lil427z is offline
call kyle at dse . go with the 9 . quada link.
rick k
Old 05-02-2010, 02:20 PM
Roadrage David Roadrage David is offline
Moser 12 bold 33 spline eaton posi https://www.youtube.com/watch?v=zn3K6d_e7bw
https://www.youtube.com/watch?v=7Dp0PngisVI
do road racing high speed runs had it up to 190mph!! beating a Aston Martin Vantage. never scipt a beat nore thuse it makes noice hell done 5000 ml of trashing didnt even changed the oil. ones. il buy another one for my 69GTO
Old 05-02-2010, 05:12 PM
brans72 brans72 is offline
I think it is odd but when I got my Chevelle couple years ago I thought about a 9 inch rear axle but went with factory 12 bolt and 33 splined axles like a year ago. Now this post pops up and guess I made right choice!!!!
Old 07-05-2010, 05:29 AM
Franks post about Power loss in the 9 inch is real great info!....
Another thing I read somewhere is the position of the 9 inch yoke can cause some Driveline angle issues when doing LS/t56 swaps....
Any truth to that?
Old 07-05-2010, 05:35 AM
Actually in some super low cars the lower pinion location can be you friend. But in a stock height car it can increase the driveshaft angle a bit. Probably not enough to cause a issue though
Frank Serafine
Old 07-05-2010, 09:16 AM
Like every car on this board. A lower pinion means less working angle and a smaller breach of the tunnel. I'll still take my 12 bolt. Me want as few Ferd parts as possible.
Old 07-05-2010, 11:38 AM
davey davey is offline
Default I choose 9"
I choose 9" because parts are easier to find (when in need), more race cars use them so more development on things occur for them meaning more options in the future, more options on brakes, rotors, axles, etc, and most of the parts for them do cost less in the end.
Sure there are a few companies that specialize in GM rear parts that are as good or maybe even better than the Ford 9", but they are just that - specialized parts.
Coming from a racing background, I know I would much rather have parts available from the local parts truck, or a good probability someone else there has spare parts that will work. That's just how I think.
